Oil Weights for Trans and Diff???
Old Mar 4, 2007 | 09:51 AM
RX8KRIS's Avatar
Speed, I Am Speed!
Question Oil Weights for Trans and Diff???
What Oil weights are you all using for the Trans and the Diff? I'm going to be changing mine out here in a week or two with RP but I'm just trying to get an idea of what to use. Right now i'm going with MT-90 for the Trans and 75w90 for the Diff let me know if it should be anything different.
Old Mar 4, 2007 | 09:59 AM
RX8KRIS's Avatar
Speed, I Am Speed!
All right my bad it seems that RP dosn't have MT-90... so once again what should I use???
Old Mar 4, 2007 | 05:19 PM
Jax_RX8's Avatar
Got Another Rotary
If your choice is RP, then you use Max Gear 75W90 in both the trans and diff - need about 5 quarts total for both.
Old Mar 5, 2007 | 01:09 AM
flomulgator's Avatar
I just did it today with 4 quarts. Actual usage was about 3.6. Manual specifies 3.2
Used RP Max-Gear 75w-90, as above. Good results.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
nowakm99
Oct 9, 2015 07:10 AM
