I Broke A Vacuum Fitting! Help!
Old Mar 2, 2007 | 09:17 AM
benfura's Avatar
I broke the upper plenum vacuum fitting while installing my REVi intake I noticed it when i drove it and I heard a hiss coming from the plenum! there was an open hole just behind the throttle, I plugged it up with proseal that i use on the helicopter main rotor head parts its designed to be all weather and stand up to 200 mph plus whatever the rotor is spinning at, on the apache, hopefully this works because a new one costs about $450.00
Old Mar 2, 2007 | 12:24 PM
Mazda-Rati's Avatar
the WANKEL made me do it
Why in the title are you asking for help if you've already fixed it?
Old Mar 3, 2007 | 12:49 AM
benfura's Avatar
just asking for all the of your guys opinion hopefully it will hold together
Old Mar 3, 2007 | 01:44 AM
MazdaManiac's Avatar
Should be OK. You might want to take the upper manifold extension off and glue it again. It is easier to see if it is completely done right.
The vacuum port is for the VFAD, so it isn't critical, especially if you have and aftermarket intake.
How did you break it?
Old Mar 3, 2007 | 01:48 AM
i would bet it will. but time will tell..
i dont know what proseal is, but if on a rotor head. i think you have solved you problem..
Old Mar 3, 2007 | 01:56 AM
edited, I was only kidding, sorry
Old Mar 3, 2007 | 07:34 AM
Exclamation
Originally Posted by TeamRX8
he should be banned for that sig pic alone, only a hot thin babe should ever be seen in that posiiton
Im second to that, Ban him !
Old Mar 3, 2007 | 12:18 PM
is it not possible to drill and/or tap a common metal vacuum fitting in it's place? I'd try that before buying a manifold
a picture would help
Old Mar 3, 2007 | 12:23 PM
davidwanj's Avatar
go to mazda ask for 4206F recall for a new engine :D
Shankapotamus3
Mar 14, 2021 03:53 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
Evan Gray
Nov 24, 2015 01:00 AM
GK1707
Sep 27, 2015 07:33 PM
