Cylinder 2 misfiring?????????? HELP
Old Mar 1, 2007 | 10:25 PM
coolme668's Avatar
my engine check light came on couple days ago, so i took it to a local autozone to have them check it with the link cables. and error message poped up on there shows that my cylinder 2 is misfirings... wtf... theres no cylinders on rx8.
does anyone know what the problem is? iam afaird to take it to the dealership cuz i got aftermarket intake and pulleys on there. i don't want them to cost me labor just to plug in a computer and check. also another error message saying that theres a miss communicate with ABS system. what does it that suppose to mean.
HELP
Old Mar 1, 2007 | 10:31 PM
dillsrotary's Avatar
jersey fresh
not sure about the ABS code, but the miss fire code happens alot, happened to me, it should clear after a couple cycles (drive the car around the next couple days, the code will clear itself). Now if you keep misfiring weekly, then you have a problem, but if this is the first time i wouldn't sweat it.
Old Mar 1, 2007 | 10:34 PM
LionZoo's Avatar
road warrior
I'm sure they mean rotor 2. The codes output all the same.
Cody Red's Avatar
always filling [the c]up
there are 2 rotors......one rotor plays the same roll of a cylinder, but just go with what dillsrotary said. i'm just saying that our rotors are our 'cylinders'
-Cody
Old Mar 1, 2007 | 10:36 PM
coolme668's Avatar
this is actually the second time it came on, i had autozone turn it off before , but a day later it will just come back.
Old Mar 1, 2007 | 10:39 PM
jersey fresh
don't have anyone turn it off, drive for a couple days. Does the car perform any differently? See i doubt its a serious issue like your coils or cat because you would def feel a sluggish engine compared to what you are use to.
Old Mar 1, 2007 | 10:44 PM
legokcen's Avatar
The Turkish Delight
For the ABS, make sure your sensors are all tight. They connectors go into the wheel hubs and can sometimes get loose from vibration.
Old Mar 1, 2007 | 10:45 PM
coolme668's Avatar
it is definity running rough, the car shakes when iam stopped at a red light. and before i had them turn it off , i ran it daily with the light on for about 2 weeks.
so stressed out about this issue.
Old Mar 1, 2007 | 10:47 PM
jersey fresh
well you didn't mention that the first time
research coils on this site, and worse comes to worse head to the dealer.
Old Mar 1, 2007 | 10:59 PM
coolme668's Avatar
does after market like http://www.vividracing.com/catalog/p...ducts_id/29674
help with anything with hp&TQ increase?
Old Mar 1, 2007 | 11:17 PM
No.
If you walk into a dealership now they can blame your pulley to be a problem ...
Old Mar 1, 2007 | 11:19 PM
coolme668's Avatar
pulley can cause problems with coils?
Old Mar 2, 2007 | 05:45 AM
Mazda-Rati's Avatar
the WANKEL made me do it
No. Pulley is an aftermarket add on that can give the dealership a reason to refuse covering your car. How recently did you install the pullies? You might need to reset the Eccentric shaft profile memory (20 brake stomps) a have the ECU relearn the pulllies
XianUnix
Sep 29, 2015 03:48 PM
Stubbs
Sep 27, 2015 04:06 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
Vedivan1
Sep 18, 2015 12:39 PM
Irvinb16
Sep 11, 2015 10:27 PM
