Techron: bad idea?
Old Mar 1, 2007 | 01:47 PM
New Yorker's Avatar
Techron: bad idea?
I use to regularly add a bottle of "Chevron PRO-GARD Fuel Injection Cleaner" to other cars I've owned, three or four times a year, usually right before an oil change. Is Techron bad for the Renesis, though?
Also, there are other Techrons I'm wondering about:
• Techron Concentrate Plus FUEL SYSTEM Cleaner
• Techron PRO-GARD Clean-Up Engine Deposit Remover
Would either of these be better than PRO-GARD Fuel Injection Cleaner? Or should I just NOT bother with any of them?
Old Mar 1, 2007 | 01:58 PM
I do it every couple thousand miles now. because I had a SSV problems before, I put some Prestone Complete System Cleaner(or something, forgot the exact name). Floor it back and fourth between the 6-7 K RPM (SSV problem) is
After 1/2 Tank, no more problems.
I wouldnt do it *too* often tho, maybe every 7-8 thousand miles.
Old Mar 1, 2007 | 02:48 PM
Jax_RX8's Avatar
Got Another Rotary
Fuel cleaners are VERY important for the rotary - more so than others due to high carbon buildup.
Techron is a good "one-time" cleaner, with "Concentrate" being the best as "Pro-Guard" is a cheaper, less strong, version. Use Techron (or other one-time cleaners) right before oil change as all of the one-time cleaners can cause some oil breakdown and increased wear when in use - good to change out oil afterwards (or most of it in the case of the 8). BG44k is a better one-time cleaner if you want to consider that as well.
The best solution IMHO is Lube Control FP60 as it is designed to be used in every tank without any adverse engine wear effects - provides great cleaners, lubricates tank/oil pump/injectors, provides additional apex and side seal lubrication, and acts as a fuel stabilizer.
FP60 has worked wonders in every vehicle I have used it in, including my 8. Quite a few others on this forum use FP60 as well. While I just use FP60 alone (4oz per 12 gallon refill), others also mix with 2-cycle oil ("premix") to get even better apex and side seal lubrication (3oz FP60 and 2oz 2-cycle per 12 gallon refill is a pretty good ratio).
Hope this helps.
Old Mar 1, 2007 | 03:40 PM
icyur2's Avatar
Shonen
Good timing! I just added in the Techron fuel injector cleaner with the Shell V-Power fuel (91 octane) and plan to drive it like I stole it ^_^ I'm thinking every 10K miles, add this with the premium fuel will help keep the carbs down!
Old Mar 1, 2007 | 05:03 PM
mzrx's Avatar
Would it make any difference if you pump Chevron w/Techron every week?
Old Mar 1, 2007 | 06:33 PM
Jax_RX8's Avatar
Got Another Rotary
Yes - but would still use FP60 as it is a much better cleaner than you will ever get from the pump. That said, using a better gas always helps - here is some more data.
Chevron/Texaco and Shell are considered two of the best "cleaning" gasolines you can buy. Both are "Top Tier Gasolines". Some other brands may be good as well, but have not gone through the top-tier certification.
http://www.toptiergas.com/
Shell V-power is particularly good - has 5 times the required minimum cleaning additives and over twice the top-tier required amounts to pass.
http://www.shell.com/home/Framework?...s_ga_0111.html
Old Mar 1, 2007 | 09:15 PM
GulfCoast's Avatar
Good information, Jax. I usually go with Shell V-Power (93 Octane).
Old Mar 2, 2007 | 08:26 AM
Landon's Avatar
Blonde Bastard
I personally stick with Shell VPower (93 Octane out here in MD) and use BG 44k every other oil change. I also use BP / Amoco as my backup fuel when I am in a crunch because of them being so highly rated as a "Clean" fuel.
Old Mar 2, 2007 | 08:28 PM
musclecarconvrt's Avatar
I just got through with a couple tanks of Techron concentrate along with Chevron gas and I couldn't be happier. I've learned my lesson. I have 68k miles on my car and had been buying gas at Sam's because is was both cheaper and right on the interstate I pass every day. Last year my car got slower and slower and slower until I had a real problem on my hands in January. I was really worried I was about to have to pop for a new engine. I was stunned how fast the Techron worked. I'm never going back to bad gas and will be treating my car to cleaner often.
Old Mar 2, 2007 | 08:53 PM
ZoomZoomH's Avatar
Mulligan User
i guess that makes you a believer out of 'not all gasoline are created equal' huh
Old Mar 2, 2007 | 09:00 PM
that's what you get for shopping at Sams rather than Costco
Old Mar 2, 2007 | 09:49 PM
I felt like a real idiot in short order. Only the best for my baby from now on. I promise
I even put my Canzoomer back on and tweaked it a bit this week. Love having my toy back to play with
WranglerFan
May 31, 2022 07:51 AM
Tweaked Tay
Sep 25, 2015 07:54 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Forevermore
Sep 20, 2015 01:04 PM
CMRine04
Sep 17, 2015 10:04 AM
