Injector questions
Old Feb 28, 2007 | 08:43 AM
cbr6fs's Avatar
Injector questions
Hi Guys,
I've been reading through the site for a while now, but this is my first post.
I have recently purchased some Injectors i'm told are from a RX8, i've searched around the net and your forum and found that the high powered RX8 has either 390cc secondary's and 280cc primary injectors sizes.
Unfortunately the guides i found so far did not give the injector part numbers though.
The one's i bought are 195500-4450 witchhunter.com list them as 425cc injectors, but i can find no reference to them on your forum.
What i would like to know is.
a/ Are these Injectors from a RX8, if so which model
b/ Has anyone actually had these type Injectors flow tested, as the manufacturers specs and actual specs are often very different with Injectors.
Thanks in advance.
Cheers
Mark
Old Feb 28, 2007 | 12:19 PM
ucleadguitar's Avatar
6 spd Newbie
The RX8 uses the 390/280 so by running the 425 the car will run rich unless you have a method of adding/removing fuel (tunning with greddy emanage, interceptor, afc).
Old Feb 28, 2007 | 12:47 PM
cbr6fs's Avatar
I don't have a RX8 i have a Miata, with Emanage Ultimate so i am able to control the bigger injectors no problem.
I have no problem with the setup and running of my car, I'm just curious
I ran 195500- 2010 RX7 460cc's previously, but the 195500-4450 Injectors improved the tickover and driveability a hell of a lot.
I would just like more info regarding which car they came from and if anyone has flow tested a set to see how the figures compare to stock.
Cheers
Mark
Old Feb 28, 2007 | 01:57 PM
Go48's Avatar
Contact Rich at Cruzinperformance.com with your questions. He can probably answer them.
Old Feb 28, 2007 | 02:40 PM
cbr6fs's Avatar
Thanks.
I've just sent them an Email.
Cheers
Mark
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Rupanrx
Sep 4, 2015 06:44 AM
