grinn253
02-27-2007, 01:13 AM
Hello,
While removing the Cat a few days ago, the 3 bolts (near the engine side) were stuck pretty good. So i used some "Liquid Wrench" as well as "PB Blaster" (could not find Kroil oil locally :( ). After letting the Cat sit for 2 nights and respraying the bolts periodically, the nuts were still stuck on. I now ventured on to a butane torch to heat up the nuts. This somewhat worked, as the nuts fell off...taking a piece of the bolt with them. :crazy: Doh! At least i was able to get the Cat off.
Question is, does the 3 bolts that are on the Cat come off, or are the welded on? They are still stuck on. May I have some suggestions on how to remove the bolts. :) I recall 'drilling them out' is what others have used, is this true? What type of drill bit is necessary?
Thanks for everyone's time.
Edgardo
The three bolts I am referring to are in the attached pic. (pix courtesy of Swoope from another thread)
http://www.rx8club.com/attachment.php?attachmentid=94772
Edgardo
