how wide can you go in front without modification
Old Feb 26, 2007 | 01:02 PM
warzol's Avatar
I am looking at a new set of rims in spring, & think I want to go with 19". It seems you can fit 9.5" wide in the back, but everyone who has this seems to have a staggered setup. I want to get the wheels as wide as possible, but not have them staggered. Staggering seems to hurt the handling a little & want to avoid that.
Does anyone know how wide you can have 19's in the front without any rubbing, modification, etc.? I couldn't locate anything doing a search, so thought I would post.
Old Feb 26, 2007 | 02:48 PM
pdxhak's Avatar
Official Post Whore
I'm running 19x8.5 255/35 front and back with no rubbing. Front is dropped approx. 1.75" and the rear about 1".
Old Feb 26, 2007 | 09:07 PM
ac3mastuh's Avatar
Got Ings?
i've heard of fitting 9.5's up front but it mostly depends on what tire size you want to run. 275's will fit with the right offset
Old Feb 27, 2007 | 09:00 AM
10" with 285/30-18
Old Feb 27, 2007 | 05:24 PM
RoXanneBlack8's Avatar
stop flooding ur engines
damn team, what offset? is the wheel the rpf1's? i now want to get ride of my hiros......
ps, if u dont want to hurt handling by having staggered tires, lets not be an oxymoron and install 19 inch wheels.....helooooooo
Old Mar 1, 2007 | 09:36 AM
warzol's Avatar
Will moving up to 19's hurt the handling much if the weight is the same or less than the stock 18's? Seems like a wider non-staggered 19" would still handle better than the stock 18". I could go 18's, but like the looks of the extra inch on the 8. I know there is more to the wheels that can help handling, but not looking to spend $2000 per wheel either. I am just looking to get the extra size and help (or at least not hurt) the handling the car currently has.
Old Mar 1, 2007 | 11:59 AM
the 285/30 has the advantage of being short, typically under 25" diameter, this helps get the wheel to avoid the fender liner both in compression travel as well as when turning the wheel
19" tends to be taller diameter, this limits the ability to get a wide tire to fit without rubbing or fender/liner clearancing
10" @ 50mm offset should clear all around, you can get it a bit further out in the front, but you'll get into the rear fender lip if you go to a lower offset #, using the same width/offset all around greatly simplifies rotation
Old Mar 2, 2007 | 09:33 AM
CosmosMpower's Avatar
1935 lbs. FTW!
I know a 275/40/17 R comp fits on a 9.5 wheel just fine.
Old Mar 4, 2007 | 01:45 PM
an 18 incher thats 10 inches wide is rare, where can u find THAT setup?
i got 18x8.5 and my 255/40s barely fit on them. offset +45 and i got an arm hairs length of rubbing inside the wheel well. how do u ppl find these wheels? is it stupid to ask if the +50 offset wheel clears over a BBK?
Old Mar 4, 2007 | 05:46 PM
255/40-18 has about a 26" diameter, I run 265/35-18 on 9.5" wheels @ 45mm offset, and they're wider than other manufacturers 275s, no rubbing and I'm at 25-5/8" fender lip height
I know people running 285s on stock wheels and factory ride height that aren't not rubbing, they're 1.5" smaller diameter than 255/40
you can always have 3 pc wheels made in 18 x 10
Old Mar 5, 2007 | 07:29 AM
ac3mastuh's Avatar
Got Ings?
whoa, i didn't know you could fit a 285 on a stock rim?
Old Mar 5, 2007 | 11:01 AM
warzol's Avatar
well, my initial thought was 19x9.5's all around. The few that I am looking at typically look like they are at 35 or 45 offset. I was thinking about running 275/30, because I figured I would need to bring it down to 30 to be able to clear, but still wasn't sure it would fit in front. I am currently running factory height & when I do get some suspension upgrades, it will be the tein FLEX coilovers, which look as though you can keep to the factory height if you want.
I might go 18x10's if I can't fit the 19's, but really like the look of 19's, but definitely will not be going staggered, even if I have to go with 18's.
Old Mar 5, 2007 | 02:50 PM
no, team, im not hittin the fender, im slightly brushing the liner inside the wheel well at full lock....its so slight its barely worth mentioning but after a few 100 miles ive seen the liner clean on certain spots on both front wheel wells.....id be much interested in fitting 285/30 on all four corners......and here i was satisfied with 255.....o well. on my 3 month anniversary of driving with my rt615s ill need new tires and ill search for a wider setup on diff wheels.....think i can get the rpf1's 10 inch wide?
Old Mar 5, 2007 | 10:15 PM
9.5s with 45mm offset are fine as long as you keep the tire's outside diameter reasonable
Old Mar 5, 2007 | 11:31 PM
RX8KRIS's Avatar
Speed, I Am Speed!
275
I've got the stock 18" rims with 275/35-18 all around and no rubbing. It came that way when I bought the car 3 weeks ago. It looks pretty tough!
Old Mar 16, 2007 | 11:01 AM
tevaburns's Avatar
drives a wagon
Tireeeeess
I just got my 275/35/18s (Goodyear GS-D3) to go with the 18x9.5 +45 Enkei RPF1's I have on order. Looking at these tires now I'm scared. HOW ARE THESE SUPPOSED TO FIT? In the same space as the lame 225s....
I found a bunch of people on this forum with this set-up (not this tire) but these wheels and 275s. Guess I'll find out next week.
Old Jul 25, 2007 | 02:39 PM
smokedRX8's Avatar
9k Redline
if i have a 1.2 " drop in the front and a 1.2" drop in the rear on eibach coil springs and i try to put on 18 X 9 inch wheels with P265/ 35-ZR 18s all the way around will i have problems?
Old Jul 25, 2007 | 02:41 PM
NgoRX8's Avatar
it depends on your offset.
Old Sep 19, 2007 | 04:11 PM
smokedRX8's Avatar
9k Redline
38mm offset
Old Sep 19, 2007 | 09:13 PM
just an update that I'm now running 18 x 10.5 +43 with 265/35-18, no rubbing or mods
Old Sep 19, 2007 | 09:44 PM
onephatguy's Avatar
18 month shelf life
I'm running 245/35/19's and I have a rub when I turn. I getting them switched out tomorrow. I have 19X8 wheels. My offset must be vastly different than other's.
Old Sep 21, 2007 | 10:16 AM
wilmic44's Avatar
Will a 245/45 R18 tire rub in the front? I wanted to have the same size tire for all 4 tires so that they can be rotated. Please let me know, because I am having them mounted on wed. Also, does the RX-8 need a four wheel alignment? I just got my car a week ago, so any advise will be helpful.
Thanks,
Mike
Old Sep 21, 2007 | 01:11 PM
pdxhak's Avatar
Official Post Whore
No fender rub.
BUT both fronts are rubbing on the inner wheel well liner. I did not notice this before so sorry for the bad information
Where are you rubbing?
Old Sep 21, 2007 | 01:38 PM
1935 lbs. FTW!
Thanks,
Mike
Should fit easily, I would go with a 40 profile though. 245/45/18 is taller than stock. 245/40/18 is roughly the same diameter as stock. 1010tires.com has a calculator where you can put in different sizes and comapre.
Old Sep 21, 2007 | 01:48 PM
Kel Rx8's Avatar
if your not 1st your last
rubby rubby no good
I believe in right offset is the key
