engine oil check
Old Feb 23, 2007 | 09:45 PM
sy02's Avatar
sy02
Thumbs up engine oil check
Dear all
i just bought a rx8 heard from my friends that engine oil need to check every week and top up?? actually type s and mazda motor 6mt wat's the diff??
cheers
new bird lost & confused....
Old Feb 23, 2007 | 09:59 PM
StealthTL's Avatar
Metatron
Cool No diff....
Just check it every second gas fill.
The engine injects oil to the rotor to lubricate it, and the oil level drops slowly. All rotaries do this, surprised the dealer didn't tell you......
S
Old Feb 23, 2007 | 10:00 PM
simply8's Avatar
white renesis*
yes....check yr engine oil level once every week, top up only when neccessary. more important thing to note is the engine oil you use...wrong oil will have serious consequences.
as for the differences between JDM and MM 6MT...just do a search.....
enjoy yr ride!
Old Feb 23, 2007 | 10:02 PM
DarkBrew's Avatar
Extraordinary Engineering
Welcome to the club! and congrats on the car.
I would strongly recommend reading your manual. This forum also has an effective search feature to help you navigate all of the material here.
To help us out please add location information to your profile and some information about your car to the garage or to your signature.
Basically you need to check your oil every other fill-up and top it up when it gets a bit low. Normal consuption is about 1 quart per 1500 to 2500 miles or so depending on how you drive with more burn during break-in.
Old Feb 24, 2007 | 09:36 AM
sy02's Avatar
sy02
thks bros,
appreciates the valuable info, will share any info if i have.
so who's better at rotary engine or should i say which workshop puts in more heart in each business
cheers
Old Feb 24, 2007 | 10:53 AM
sy02's Avatar
sy02
i read all the discussion about oil chnage and others issue,i am lost tomorrow going to mazdamotor to query them.
Old Feb 27, 2007 | 11:45 PM
Calvin Kong's Avatar
How about RE雨官 SuperG for NA ENGINE OIL 0W-30 SL/CF. Is it good for RX8 ?
Old Feb 28, 2007 | 03:25 AM
sqflyer's Avatar
Heavy Machinery Operator
Yup, it's good. If RE is bad for the RX-8, then I really dunno what is good liao. Having said that, I'm still running on mineral.
Old Feb 28, 2007 | 03:47 AM
pyro's Avatar
Bui Eh Bui Liu Liu...
Bro, you on shell mineral?
Old Feb 28, 2007 | 03:53 AM
sqflyer's Avatar
Yup. Regular Shell mineral as used by MM. Cheap to change, cheap to top-up and can't go wrong with mineral oil on our Renesis.
Old Feb 28, 2007 | 03:55 AM
pyro's Avatar
Thanks for the info.
Old Feb 28, 2007 | 04:41 AM
Mazdaspeed 88's Avatar
Limited
what if i use shell semi sinthetic oil?
Old Feb 28, 2007 | 05:31 AM
gfoo's Avatar
Just either use Shell Mineral or Fully Syns that are designed for Rotary (RE, Idemitsu, RMagic). The only semi syn i know that's good and for rotary is Trust
Old Feb 28, 2007 | 06:20 AM
sqflyer's Avatar
You're braver than me... I wouldn't use any synthetic (or semi) not specifically made for rotary engines.
Old Feb 28, 2007 | 09:59 AM
Limited
thanks guys for the suggestion and advises.
Old Feb 28, 2007 | 09:12 PM
sgrenesis's Avatar
THE GREAT WHITE
Shell fully syn can use meh???
Old Feb 28, 2007 | 09:28 PM
CoupeM's Avatar
Night Rider
hehehe
Old Mar 1, 2007 | 06:13 PM
looking4's Avatar
Red RX8 in Philippines
shell mineral
sqflyer, can you give me the exact viscosity of shell mineral oil that can be used for RX-8? I am here in the Philippines and nobody knows anything about which mineral to use. Thanks in advance.
Old Mar 1, 2007 | 10:02 PM
coupe07's Avatar
SC 300HP!!
if we are talking abt mineral oil, then it doesnt have to be brand specific. Sporeans use shell becos spore Mazda Motors tie up with Shell.
For mineral oil, any brands will do. generally mineral oils have higher viscosity
Old Mar 1, 2007 | 10:41 PM
lennon's Avatar
Wasn't Trust Fully Syn??? Have to go back n check...
Old Mar 1, 2007 | 10:50 PM
Swerve76's Avatar
Have to agree with Sqflyer here - I personally would never use syn or semi-syn in my car.
Just paranoid that syn, even the ones specifically engineered for rotaries, will not burn as cleanly as minerals. That can and will lead to a buildup of sludge which would ultimately mean that ur engine is farked.
Just my 2c (*raises flame shield*)
Old Mar 1, 2007 | 11:17 PM
coupe07's Avatar
SC 300HP!!
Trust has Full syn n Semi syn.... F2 and F3 respectively.
Old Mar 2, 2007 | 04:52 AM
Genesis's Avatar
Driving Me Crazy
Yup I'm with sqflyer too....been using Shell Helix Super 20W50 since day one. I've found that checking oil levels every other fill-up is a bit extreme. I only need to drop in a fresh half-litre every 2500 km's.
Old Mar 2, 2007 | 07:39 AM
sqflyer's Avatar
Ha ha.. didn't know so many other people as cheapo as me... j/k guys
Old Mar 7, 2007 | 12:30 AM
sy02's Avatar
sy02
HI all,
After getting my ride, i have been enjoying it. I heard that HKS re oil is not bad anyone tried before?
