View Full Version : Timing Problem ?????
WreakLoosE
02-23-2007, 09:44 PM
Hay guys... I got a new A Gen Cy Power pully for my 8 today and put it on... Everything is all good and fine with the install however, I got a CEL for P0302 Cyl. 2 Misfire detected... Now when I installed the pulley I noticed that I spun the crank when I was trying to take off the bolts that hold the pulley on.. Did this mess the timing up some how?? and if so... How do I check the timing and correct it?? any help would be nice... Thanks..
StealthTL
02-23-2007, 10:01 PM
I think you just pull the battery cable off, to make the ECU forget the screwed-up timing setting, and set a new one.
S
WreakLoosE
02-23-2007, 10:07 PM
I thought of that.... Didnt work...It came back on...I will try to drive it more to see if it retimes it self..
StealthTL
02-23-2007, 10:25 PM
We should both have consulted the sticky thread in the Tech section - "How to reset the ECU"
Link (http://www.rx8club.com/showpost.php?p=349432&postcount=3)
MazdaManiac posted the reset procedure. :rock:
S
WreakLoosE
02-23-2007, 11:35 PM
Nope Still nothing... CEL still lit.. When I disconnect the batterie it goes out and when I start the car it is off for about 3-5 mins. then comes on...
Razz1
02-23-2007, 11:46 PM
Search.. there is ananswer on the forum.
Also good information at MazdaTrix site.
WreakLoosE
02-25-2007, 03:30 AM
OK I fixed it.... After Crank is moved from its possition the computer sensors need to be reset... the KAM the 20 presses on the brake did the trick...
StealthTL
02-25-2007, 05:38 AM
I posted that in post #4, you didn't follow the Link.....
S
