View Full Version : Car wont go into 2nd
Gauge
02-23-2007, 05:08 PM
Hola, I have a 2004 rx8 and for the past week, it doesnt want to go into 2nd gear . Once I get going and stop later on and take off it gets easier to get into 2nd . It doesnt make grindin noises or anythang, it just doesnt want to go into 2nd . Wondering if anyone may know why ? Clutch? Transmission? You have to pull pretty hard to get it into 2nd.
abbid
02-23-2007, 05:21 PM
Whats the build date there lil fella..
check on driver door vin panel..
Dont force it in, youll only make it worse.
Go48
02-23-2007, 06:47 PM
Have a dealer check it out. There have been a few problems reported with shift forks and clutch pressure plates.
Gauge
02-23-2007, 07:27 PM
Under date it has 05/04
The car seems a little rough going into gear also . (all gears)
Razz1
02-24-2007, 12:00 AM
Change the gear box fluid and it may go away.
JB_Rotary
02-27-2007, 11:46 AM
Change your gear fluid if not have a dealer look at it and tell them the shifter fork is messed up probably bent. Then get a stainless steele clutch line so at high RPM and fast shifting it won't happen again.
