Bad Clutch Problem ,,Wont go into 3rd gear sometime
Old Feb 22, 2007 | 09:39 PM
sauceyI986's Avatar
I have a trasmission problem when i just doing normal driving/ not speeding , press in the clutch pedal then try to shift into 3 and i hear my gear grind then i have to depress and press again for it to go into gear. this doesnt happen all then time but its like an every other day thing..
Old Feb 22, 2007 | 10:46 PM
Winning 8's Avatar
Hot Pit
clutch slave, or master going, take it in to the dealer.
Old Feb 23, 2007 | 03:54 AM
Stavesacre21's Avatar
1.21 Jiggawatts
either that or a bad syncro. I'd hope it not be the latter though...
Old Feb 23, 2007 | 06:05 AM
sauceyI986's Avatar
k thanks and i setup sometime so i can take it to the dealer before i take my trip to cali again
Old Feb 23, 2007 | 03:42 PM
kwescott's Avatar
One ball, corner pocket
I was having some grinding issues as well with Amsoil fluid....switched to Royal Purple and the grind is gone. Are you using sythetic transmission fluid?
xAgyex
Jun 3, 2026 03:47 PM
Dokuji
Nov 1, 2016 02:51 PM
uZu
Dec 30, 2015 12:35 PM
Tailicus
Sep 2, 2015 12:38 PM
GracefulShanks
Aug 18, 2015 11:40 AM
