1st gear thud
Old Feb 22, 2007 | 07:36 PM
delhi's Avatar
Grand Chancellor
1st gear thud
I was test driving an 05 GT today and from Neutral to 1st, there seemed to be a thud from the tranny or diff. I don't know. Is that normal? Other gears were fine.
Old Feb 22, 2007 | 07:42 PM
DarkBrew's Avatar
Extraordinary Engineering
A bit of a thud or shudder is normal (at least mine does it)
Old Feb 22, 2007 | 07:51 PM
delhi's Avatar
Grand Chancellor
everytime it shifts to 1st from N? this is a first time in all the manuals I've driven.
Old Feb 22, 2007 | 07:55 PM
early 30's crisis's Avatar
destination anywhere..
+1
Old Feb 22, 2007 | 09:25 PM
LionZoo's Avatar
road warrior
Mine does it too.
Old Feb 22, 2007 | 10:10 PM
mine does it as well. I'm chalking it up to 'quirks of the car'
Old Feb 23, 2007 | 05:39 AM
Go48's Avatar
Sounds like the clutch may not be completely disengaging or you are rushing the shift.
Old Feb 23, 2007 | 11:57 AM
delhi's Avatar
Grand Chancellor
How would I be rushing to shift when it is from N at a standstill while waiting on the light? i'm gonna try another rx-8 to confirm.
Old Feb 23, 2007 | 12:18 PM
GT34's Avatar
Wanna touch my wankel?
I noticed that too. But it only happens once after I've come out of a high gear into neutral. It doesn't make the noise after I go 1st, N, 1st, N. I've also noticed sometimes while I'm driving it can be hard to go into first from N
Old Feb 23, 2007 | 01:55 PM
Go48's Avatar
Well, let's see. You're sitting at the light with the clutch engaged (i.e., pedal out), the light changes, you push in the clutch pedal and immediately drop it into gear. Crunch, thud (or insert your description of the sound of a spinning gear or two trying to mesh). Not saying you are doing that, I'm just posed that as a possibility for the source of the sound you are hearing.
FYI: The transmission mainshaft is turning when the clutch is engaged (i.e., pedal out) in neutral. (Listen for the sound of the shaft "rattling" against it's bearings in a quiet area.) So when you push in the clutch pedal (disengage the clutch) it takes a bit of time, like a second or less, for the main shaft to spin down. If you shift before that happens, you can get a crunch, thud or whatever you want to call it.
Old Feb 23, 2007 | 03:09 PM
delhi's Avatar
Grand Chancellor
I hear you go48. It just felt strange. I know it happens to my other cars if I shift fast during autoX, which I attribute to differential shock (Subarus & miata), but never while putt-putting on the streets.
Will changing the tranny oil to synthetic help?
Old Feb 23, 2007 | 03:12 PM
chrism's Avatar
Misfit Moderator TnC
i think we all get the thud for first
Old Feb 23, 2007 | 03:29 PM
otherside's Avatar
I dont care...
Normal characteristic.
Old Feb 23, 2007 | 04:54 PM
Go48's Avatar
Can't hurt. Even if it doesn't get rid of the thud, shifting should be noticably smoother.
Old Feb 24, 2007 | 06:25 AM
Mazda-Rati's Avatar
the WANKEL made me do it
Mine does that before I even put it into 1st gear. Right as I begin to slide it into first gear it thuds. Been doing it for 35K miles and it hasn't got better or worse. So I figure it has to be normal. Also changed to Redline fluids 15k Miles ago and no difference.
Old Feb 26, 2007 | 12:11 PM
delhi's Avatar
Grand Chancellor
I test drove another 05 gt yesterday. No thud whatsoever from idle/N to 1st. Hmm....
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
