View Full Version : car pulls sumtimes
prospectjtaz
02-22-2007, 06:55 PM
So ya, looked over cant really find anything, please dont flame. Just got the car, but sumtimes wen im driving, it will pull either to the left or right, its understandable sumtimes cuz of the road, but sumtimes the road could be perfect and it still does, even wen braking sumtimes. Is something wrong with the differential? A noob to the mechanics of the car, so any help would be appreciated. Also hearing a ringing sound when accerlating after switching gears, goes away when I give it more gas, normal or...?
staticlag
02-22-2007, 07:09 PM
How many miles are on the car?
Is it modified?
How many miles have you personally driven it?
8is>enuff
02-22-2007, 07:10 PM
As for the pulling, look up tramlining. There's a good article on it on Tirerack.com and a bunch of info on it here.
No clue about the ringing, unless you have a 6MT and you're talking about the shift beep, which is an auditory reminder to shift gears and goes off at 8500RPM.
prospectjtaz
02-22-2007, 07:28 PM
its got 33 000 miles on it, drivin prolly less than a 1000. no its not the redlining beep, and its bone stock.
staticlag
02-22-2007, 08:05 PM
The ringing is the ports on the engine opening, it is normal.
The previous owner probably replaced one flat tire but left the others in worn condition. So one good tire is gripping the road but the rest need to be replaced. Look at the brand and treads of all 4 tires and see if this is the case.
DarkBrew
02-22-2007, 08:35 PM
Maybe you could post a bit of information about yourself and the car in your profile or in your signature... (look under user/cp)
What kind of tires are on the car? Stock wheels?
prospectjtaz
02-23-2007, 10:18 AM
18" brand new khumos
BlueRenesis82
02-24-2007, 12:33 AM
is english your first language?
Razz1
02-24-2007, 12:51 AM
30k miles get an alignment.
The ringing, my bet it's normal. Do some more reading hear.
Welcome to the club.
coolme668
03-01-2007, 11:39 PM
do you directional tires?
that might be the problem if you do.
