?question?
Old Feb 11, 2007 | 01:16 AM
ARC.4.LYFE's Avatar
Question ?question?
once i've got the amp powered, grounded, hooked up to an ignition controlled 12v supply, and the sub wired up i splice the ends of my RCA cable and solder it into the corresponding wires that plug into the stock bose amp, is that correct??
Old Feb 19, 2007 | 02:27 PM
TheBri's Avatar
Spastic Monkey
If you keep asking the same question over and over again eventually someone will give you the answer that you're fishing for...
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
