sauceyI986
02-08-2007, 07:25 PM
I was going to buy some wheels next month but I can't decide on 19's or 20's the of the rims will be
front 20x8.5 rear 20x10 with a 2" drop
View Full Version : will 20's work with a drop sauceyI986 02-08-2007, 07:25 PM I was going to buy some wheels next month but I can't decide on 19's or 20's the of the rims will be front 20x8.5 rear 20x10 with a 2" drop EZZY 02-08-2007, 09:54 PM is there a reason to go 10" wide at the rear...? you can still lower it depending on the offset... Razz1 02-08-2007, 10:14 PM There's gonna be very little room to drop it. Your stopping and handling will suffer. You wlll not be able to hit 0 to 60 in 8 sec. phat8 02-09-2007, 10:57 PM this is what i've experienced, hope it helps...i got 20''s. only cos i could'nt get the style i wanted in 19''. my suggestion is to get 19''s, unless u gonna turbo ur 8. cos the 20''s slow the 8 down alot and when i had my 1st set of wide 275/20''s, i found the 8 feeling very much like if example the RH wheel went over a small dip in the road it would pull to the RHS. it was'nt pleasant, now have 245/20'' on and feels better. especially with the drop ... i've managed to lower mine, S.A measurements in mm. 15mm at the rears and 30mm in the front. had a arch trim at the back cos it was scraping. now no scraping and wheels fill the arches alot better than the 18''s. |
