rotarygod
02-08-2007, 05:48 PM
There have been many people who have gotten the cat inefficiency code. Yes it will happen if your cat goes bad but we've also seen it from time to time on high flow cats too. People automatically assume that the cat is going bad. It might not be if it is a high flow unit. I spoke to Chris at Cobb Tuning today and somehow the subject came up but on Subarus. They have the same problems in many ways that the RX-8's do. The biggest difference is that they've learned which ones they need to pay attention to and why some of them appear when they do.
The cat inefficiency code is calibrated to see a certain value. If your cat is plugged up, it'll throw the code. Conversely if your cat flows too good, you can still throw the code. It's not to say it will always happen, but it can and sometimes does. This doesn't necessarily mean that the cat is failing. It just means your cat isn't working within the range of operation that the factory sensor wants. If you have a high flow cat and get this code, your cat apparently does work as advertised. These are issues that the Subaru guys have had with exhaust changes and it sounds all too plausible that this is what happens with the RX-8 as well. This is just the way ecu's work nowdays. The Subaru fix with the Accessport is not to reset the CEL but rather to disable the sensor altogether so you never get it.
If you have a high flow cat and you get this code, maybe you do have a problem with your cat. On the other hand, maybe you don't and it works just fine. The biggest problem is that it may be an inconsistent code. It may show up one random day after not having it. Just thought the info was good.
