NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Questions from a stick rookie!!!
Old Feb 5, 2007 | 07:28 PM
NoOdLe BoY's Avatar
Question Questions from a stick rookie!!!
wass good!!
As some of u know i just got my rx-8. ITS MY 1ST STICK SHIFT CAR. ive driven it for like a total amount of 4 hours??? lol. im still practicing my 1st gear i dont stall out but i take a lil long to go, and wen i switch gears im not smooth alot of times. you might be wondering: "didnt he post that he beat an s2000?". its true but racing is no problem for me, its just driving normal i have a hard time with. lol. so if u got any tips or comments please post them. and i have some questions too.
ROOKIE QUESTIONS
1. the rotary sound is very different from a normal engine rite?
2. wen i have the heater on and im gettin air from outside is it supposed to have a small oil type of smell?
3. what should i look out for?
4. am i stupid n really slow? (mind that im new to this!)
good lookin out
Old Feb 5, 2007 | 09:10 PM
Gambit's Avatar
Screw gas mileage
1. yes
2. the smell is normal, and has nothing to do with heat. it'll go away in a month or so
3. let it warm up, and don't stall it out. just watch your rpm needle, if you see it heading toward zero, push in the clutch and the gas
4. you'll get the hang of it
5. if you beat an s2000, it's because he wasn't racing you
Old Feb 5, 2007 | 09:12 PM
llzjayarzll's Avatar
meow
hmmm all our sounds are different, most of us have upgraded midpipes/cats and aftermarket catbacksetups and intakes which make everything sound different. rotary does have a different sound and it can be projected a little more with some selected stuff i.e racing beat.
go to the dealership, theyll fix it for free.
flooding.
search.
Old Feb 5, 2007 | 09:15 PM
dillsrotary's Avatar
jersey fresh
PRACTICE! no better spot that NYC traffic
j67345's Avatar
Wow, great questions.
1. Actually, the rotary sounds exactly the same as a normal engine. There's no difference...mainly because even though it's called a rotary, it still has 3 pistons in the 'heart' of the engine. These pistons will be used when the Mazdaspeed RX-8 is released. Therefore it sounds exactly the same as a normal engine.
2 The oil smell probably means one of the three pistons in the rotary engine aren't firing correctly.
3. You should look out for Kia's (in general). They are very dangerous.
4. Stupid n really slow all depends on what scale you are being graded on....
Old Feb 6, 2007 | 05:56 PM
Critzman's Avatar
Velocity
My g/f wants to learn to drive stick... on my 8... I laugh... I learned to drive stick on a 1990 Geo Tracker when I was 17... taught 2 ex g/f's to drive stick on my old E36 Bimmer... just take your time... drive it everyday... try to stay out of traffic and situtations that might make you nervous... and one day it'll all kick in...
As for beating an S2K... I ripped one on Myrtle Ave in Queens a couple months ago... and yes he was racing... and reving... but maybe he lacked the *****... who knows...
-Brian
Old Feb 6, 2007 | 06:11 PM
otherside's Avatar
I dont care...
Wass good? Good lookin out? Man I'm old. I'm assuming thats the same as "Whats hapnin" and "Peace out" ?
Old Feb 6, 2007 | 07:29 PM
NoOdLe BoY's Avatar
lol. thanx for the advice man. ill try to stay out of situations like that but they're inevitable. lol. and for otherside, "good lookin out" is like saying thanks n appreciate it.
Old Feb 7, 2007 | 05:46 AM
Gambit's Avatar
Screw gas mileage
if you teach her properly there's nothing to worry about
Old Feb 7, 2007 | 07:31 AM
Aero8's Avatar
^ it's true, I've taught a couple people in my 8 now.
1. yes
2. I have smelled it too, I hope it is normal
3. stare at your feet the whole time to make sure you are doing it right
First gear, go to a parking lot that is relatively flat, stop and then slowly, very slowly let the clutch out. as it starts to engage the car will start to roll and with no gass will keep moving at about 5mph. it isn't the best on your clutch, but won't kill it either. the point of this is to get used to where the clutch engages. after you think you have a feel for it start adding gas. and keep practicing until you think it is getting smoother, then take it out on the streets again. This may be a very beginner style approach, but it will help you make your shifts smoother and as you get used to it you will be faster.
When you are shifting to other gears, second can be just as picky as first, so don't feel bad about that one. 3-6 you just need to get used to after driving awhile.
4. I would say no. I only had a few hours in a couple cars drving stick before I went to buy my 8. It took me about a month to get really used to driving stick and making it smooth. There are still times that a shift will be a bit rough, but hey, no one's perfect
Keep driving and you will get used to it, it will just take some time.
Old Feb 8, 2007 | 08:04 AM
Critzman's Avatar
Velocity
Oh I can teach her properly... just not on my car... she wants to pick up 'a little something' soon in stick... then I'll take all the time in the world to teach her...
-Brian
Old Feb 8, 2007 | 08:09 AM
mysql101's Avatar
getting the car to move from a dead stop in 1st was tricky for a while, a little too much and you'll over rev and feel silly. Too little and it'll start to bog down. You'll eventually be able to sense how much throttle and clutch is needed, and can make adjustments on the fly if you misjudge. It just takes time.
Also, if you really want to be able to shift nicely, look into getting the AFE short throw shifter. You'll drop the time it takes to move into gear by 2/3rds with it.
Old Feb 8, 2007 | 08:54 AM
Aero8's Avatar
Totally agree about the AFE short shifter, Great product and not horribly expensive.
Old Feb 8, 2007 | 09:25 AM
RX-XSIV's Avatar
turbo'd w/ excellence
make sure u warm the car up before for a good 5-10 mins before you go anywehre.. god forbid u start up the car, put it in first and stall out.. then you got a flooded engine and that sucks .. so0 let the car warm up before you drive her.. not just when ur learning stick..but everytime..its better for the engine, plus ull get better gas milage haha..good luck with the car tho! u live in queens? i used to live in south ozone park.. i live in oceanside now on long island..right next to valley stream kinda
Old Feb 8, 2007 | 09:29 AM
RX-XSIV's Avatar
i first practiced trying to drive stick on my aunts saturn.. man i suckd at first..but after i drove it for like an hour i was gettin the hang of it and started to get a lot easier.. then i bought my 1st car.. my integra w/ a TWM short-shifter.. wow... short inst the word. the throws were about the same as a 911 turbo.. flick of the wrist... i have a picture i think
[IMG][/IMG]
Old Feb 8, 2007 | 09:30 AM
RX-XSIV's Avatar
and that was the nicest shift **** in the world :'( ... stainless steel.. $115 but it was so nice
Old Feb 8, 2007 | 10:28 AM
Landon's Avatar
Blonde Bastard
Originally Posted by NoOdLe BoY
wass good!!
ROOKIE QUESTIONS
good lookin out
1.) To me a rotary sounds a little different but I guess its all in the person. Even people on the road are confused when they hear it but then again I have the MS intake and exhaust.
2.) I have the same issue, there isn't much to worry about. Usually after the car is going for a while the smell goes away.
3.) HILLS! If you can find an area with not a lot of cars and practice taking off going up hill. This will train to you make FAST and correct shifts. To me thats how I learned because if your too slow you will drift backwards and possibly hit something.
4.) No, Not everyone learns to drive a stick. BTW kudos on getting the manual over the auto, you will be MUCH happier.
Old Feb 8, 2007 | 12:08 PM
dmc27's Avatar
doin' the bull dance
Every engine will have a different "note"
Smell is normal and will go away IF it's brand new.
Practice in a parking lot or somewhere w/no traffic, preferably w/some slight grade to the surface, so you can get used to the difference in downhill v. uphill launch.
j67345 is dead w/this: "Stupid n really slow all depends on what scale you are being graded on...." lmao!
oh, and otherside is old. hahahahahahahhahaha!!!!
Old Mar 12, 2007 | 08:33 AM
J2R's Avatar
J2R
Jess VR 04 & Mike NG 04
Dude you got enough air freshners under there.
Old Mar 12, 2007 | 11:42 AM
chizzer337's Avatar
hahaha went there the 2nd day I got my whip.
Old Mar 12, 2007 | 12:05 PM
SoFL_RX8's Avatar
Former Owner
Is this guy serious?
ASH8
General Automotive
2029
Apr 10, 2026 02:06 PM
BERG
Oct 8, 2015 09:28 PM
jer2911
Sep 29, 2015 06:37 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
teamdipngo
Sep 14, 2015 02:47 PM
