View Full Version : what can cause catalytic failure
turbosa22c
02-03-2007, 06:30 PM
heres a link i found. straight forward easy to understand stuff. might help someone.
http://www.car-sound.com/04basics/04failures.asp
foo77
02-03-2007, 11:56 PM
nice find :icon_tup:
Wilson
02-04-2007, 12:41 AM
Yes. Very good info.
d j
02-04-2007, 01:51 AM
thanks for sharing!
nycgps
02-07-2007, 02:34 AM
Answer : Human beings.
4 years to Supercharge
02-07-2007, 04:13 AM
It a catalytic convertor gets clogged or a meltdown occurs can that be seen by looking down the pipe?
I noticed that all the examples had the catalytic cut in half to show the damage. :scratchhe
Jax_RX8
02-07-2007, 10:30 AM
No wonder our 8's have so many catalyst failures - we have all the characteristics that destroy converters (and more?):
- more unburned fuel than a piston engine entering exhaust causing higher EGTs and carbon buildup
- oil being added to the combustion process via the OMP and Premix causing even more carbon generation
- carbon buildup fouling the plugs and amplifying the unburned fuel problem
- all this super heating and clogging the converter at the same time
- all this excess converter heat backing up causing higher engine/exhaust/combustion temps
- More heat stress on all engine components
What to do? Glad I run FP60.
Ajax
02-07-2007, 10:14 PM
So i thought mine was failing this week and it turns out i needed 4 new plugs and 4 new coils.. and it probably was failing, because needing 4 new plugs and 4 new coils would cause the damn thing to eat unburnt fuel..
they shoulda replaced it..
blah.. dealerships..
Razz1
02-07-2007, 11:01 PM
Samething we been saying for years, but another sight helps those that question us.
nycgps
02-08-2007, 12:01 AM
I had mine replaced because *SHHhhhhhhh* I dont want to say it here.
When he show me the *dead cat*, it was actually all empty inside .... damn now when I think of it, I should've asked him *Can I keep it?* lol guess not, I think dealerships need the old parts to get credit for new parts.
Georgia8er
02-08-2007, 10:29 AM
Even though an RX-8 runs rich, too lean will burn up the cat too. Your EGT will increase with a lean condition also.
