13B-REW swap
Old Jan 29, 2007 | 03:02 PM
sixgen3sgte's Avatar
2JZ Powered
13B-REW swap
Hi guys, i was doing some research on swapping the 13B-REW into the 8, but all i find was a bunch of info stating how bad of an idea it is from two years ago
i am just wandering if anything has changed in that time
i wouldn't even be asking this question if someone hadn't suggested this to me
and after consulting Scott at mazsport about it, it may be an option
just looking for reputable input, if anyone has some knowledge on this topic please post, i do not need haters please lol
thanks
Old Jan 29, 2007 | 03:06 PM
chickenwafer's Avatar
Nope
A 13b swap would be cool. More potential, as of now. But seeing as you are already turboed, why do a 13b?
Dave
Old Jan 29, 2007 | 03:52 PM
Renesis_8's Avatar
He wants more power, he has the SSR turbo, which pushes more than the greddy already. going with 13B-REW will probably require major modifications/$$$, why not go 20B? There is already a car in Scott's garage undergoing that already.
________
HornySolenn live
Old Jan 29, 2007 | 09:35 PM
thyt would be taking one step forward (buying an RX-8), two steps back (swapping the Renesis with an older rotary) ...
Old Jan 29, 2007 | 10:01 PM
Cody Red's Avatar
always filling [the c]up
if you do do it, post pics, vids, and more pics
-Cody
Old Jan 29, 2007 | 10:54 PM
2JZ Powered
i don't want to do the 20b its just too much money, and realisticaly i don't need that much power
my motor is currently BLOWN!!! so... i'm at a cross roads
i originally talked to mazsport about reparing the motor and making it a little more reliable
i am looking to make about 350rwhp reliably (in other words i don't want to have to rebuild the motor every year
so after extensive talk with Scott, i got a very "round about" price range of 7k to rebuild everything and get it in tip top shape depending on how damaged my motor is of coarse
well after someone suggested it to me and a little research i talked to Scott about the 13B-REW swap. he said it would be a little more expensive, because of the extra work but most likely less repairs on the actual motor will have to be done, and the biggest factor is i could sell my kit
also he did state that it could make more power more reliably just because it has been around longer and there is alot more knowledge for it as far as tuning goes
now all of this does depend on that, i can't sell it then i have no choice
i am also having 2nd gear synchro problems
so using the rx7 5spd is something i was wandering about as well
scott said he should be able to make it all work fairly easy, the hardest parts would be the motor mounts (he said they shouldn't be that bad, and i will most likely go solid), and i would have to use the 8 ecu to run the paramaters, and probably a power fc for the motor
Old Jan 29, 2007 | 10:55 PM
2JZ Powered
also we were talking about the JIC car and i can't seem to figure out why the firewall would have to be cut
Old Jan 29, 2007 | 11:24 PM
SlayerRX8's Avatar
'03 Dodge Viper
This video has an rx-8 with a 13b-rew installed in it - after they talk about the rx-8 a little bit.
Maybe this is some good motivation?
http://videos.streetfire.net/search/...ba00561afb.htm
Old Jan 30, 2007 | 03:18 PM
2JZ Powered
yeah i wish i could get some better engine bay pics of that car
i have a few of it an the Ganador car that rod millen drives but i can't seem to figure out where they cut the firewal
but both of those cars did alot more than just the swap they converted o all hydrolic brakes and tons of other race car stuff because of the stress that will be put on the cars in drifting
Old Feb 22, 2007 | 03:13 AM
2JZ Powered
hmm, thats interesting
I am actually currently looking in another direction
unfortunately my experiance has kind of turned me off to rotarys (not that i don't still love and respect them)
its just that i have alot more experiance with inline 4 and 6 cylinder motors
so i might have to comit with sacrolidge and go piston (just NO v8s)
But we shall see, nothing is in stone
Old Feb 22, 2007 | 06:04 AM
Fanman's Avatar
Why no V8 ? If you are going to make the switch then there is plenty of V8 LS1 experience with the RX7's. If anything you have much more expertise with that then if you tried to put an I4 or V6 in there.
As for going with a 13B REW. Do you need smog approval. Out here in Cali. I don't believe you can do that, as you have to get an engine that is as current as the car or better.
I feel you on the blown engine. Happened to me, and needless to say it is probably one of the most frustrating feelings I have ever had.
Old Feb 22, 2007 | 07:58 AM
MadDog's Avatar
Consiglieri
Its not just a California requirement, that's a United States EPA requirement.
Old Feb 22, 2007 | 08:54 AM
2JZ Powered
First off, I am in Mississippi and I dont have to worry about any of that smog stuff and the cops around here dont know anything.
And when I said experiance, I meant my experiance. I have much more experience with inline 4s and 6s.
Old Feb 22, 2007 | 10:09 AM
Red Devil's Avatar
I say if you're willing to take it on, go for it...getting 350whp would be simple with a REW.
On your current turbo setup, where were you reaching full spool?
Old Feb 24, 2007 | 03:07 PM
2JZ Powered
Full boost hit right before 4k
Old Feb 24, 2007 | 03:53 PM
2JZ Powered
Yeah actually thats who i was talking to about doing the 13b rew swap it wasn't going to cost much more than rebuilng my motor and then reaching my hp goals
Old Feb 24, 2007 | 05:31 PM
Digital_Damage's Avatar
All I can say is, why? Just when things are getting interesting you want to take a step back instead of foward.
Old Feb 24, 2007 | 05:57 PM
mike1324a's Avatar
Need'd a Turbo
If your only shooting for 350whp wouldnt it be possible just to keep the same tranny? Does anyone know what tranny is in the JIC 8?
Old Feb 24, 2007 | 06:23 PM
N rider89's Avatar
^NieL
its an easier more well known powerplant for higher hp #s. im not try ing to argue which is better but the 13b-rew has had a lot more development and it is well know what they can achieve now
Old Feb 24, 2007 | 06:34 PM
stickmantijuana's Avatar
Unregistered User
why? lower compression rotors.
i don't think it's taking a step backward. it's just a different way of tuning.
some like high reving NA; some like massive turbo boost. neither is "wrong", yes?
Old Feb 25, 2007 | 12:37 AM
mike1324a's Avatar
Need'd a Turbo
My point exactly!
Old Feb 25, 2007 | 08:55 AM
2JZ Powered
Yes i'm definately the big boost guy i just love the sounds and then the big boost of power it's just so much more fun being fast with a turbo
Old Feb 25, 2007 | 07:00 PM
YayAreaBruh21's Avatar
how can i get ahold of the JIC guys? im very interested in this as well.
Old Feb 25, 2007 | 07:03 PM
Unregistered User
haha make up ur mind. ls1 or 13b?
Old Feb 25, 2007 | 11:37 PM
Seeing the prices and the different capabilities.. what fits me more is what im mostly interested in. sorry for havin multiple interest?
