View Full Version : Higher Redline
crossev
09-11-2003, 11:56 PM
I have a question when it comes to RPM's the RX-8 has an higher redline compared to the 350-Z and the G35 coupe. What does this mean and how does it affect the car.
khoney
09-12-2003, 01:34 AM
Makes it more fun to drive :D
5Gen_Prelude
09-12-2003, 01:54 AM
Assuming your engine can work efficiently at that RPM, you can produce more HP the higher the RPM is. There gets to be a point where you can't rev any higher effieciently cheaply, thus lower redlines for other engines. When you compare the designs of a piston engine and a rotary engine, it's pretty clear that it's easier to rev a rotary since you're not pushing the pistons in, then out.
The other advantage of a higher redline is that you can use gearing to your advantage.
dcfc3s
09-12-2003, 08:35 AM
The only thing really holding the rotary back from having an even higher redline is the belt-driven accessories - AC compressors and alternators don't like spinning at insane RPM's.
You also start sacrificing low-end power and driveability for higher RPMs. The variable intake ports and the like are why the '8 is as driveable as it is with a 9000 RPM redline. To make power up top, you really need to be able to get air in and out of the engine efficiently!
Dale
rotarygod
09-12-2003, 09:51 AM
If you don't have forced induction or nitrous there are only 2 ways to get more power (porting being equal). One way is to increase displacement and the other is to increase rpm's. We definitely don't have the displacement.
