Mazda PIDS
Old Jan 22, 2007 | 12:15 PM
LostAngel's Avatar
Mazda PIDS
Hey everyone, I was wondering if anyone had a list of the PCM Parameter Identification (PIDS). They define things such as RPM, Fuel Pressure, Air Temp, etc. I've seen a few posts mentioning them, but have not seen a list.
Old Jan 22, 2007 | 04:25 PM
jzrx8's Avatar
Drive Like You Stole It
so you want the specs on the PIDS you listed?? If so give me a couple minutes and i will post'em up.
Old Jan 22, 2007 | 04:28 PM
jzrx8's Avatar
Compression pressure
Standard 830 kPa (8.5 kgf/cm2, 120 psi) [250 rpm]
Minimum 680 kPa (6.9 kgf/cm2, 98.6 psi) [250 rpm]
Standard difference in chambers:
Within 150 kPa (1.5 kgf/cm2, 21.8 psi)
Standard difference in rotors Within 100 kPa (1.0 kgf/cm2, 14.5 psi)
Old Jan 22, 2007 | 04:29 PM
jzrx8's Avatar
Oil pressure (reference value) [oil temperature: 100°C (212°F)] 350 kPa (3.57 kgf/cm2, 50.8 psi) [3,000 rpm]
jzrx8's Avatar
Fuel line pressure 375 - 450 kPa {3.83 - 4.58 kgf/sq.cm, 54.4 - 65.2 psi}
Fuel hold pressure 200 kPa {2.0 kgf/sq.cm, 29 psi}
Old Jan 22, 2007 | 04:30 PM
jzrx8's Avatar
Initial-opening temperature 80 - 84°C (176 - 183°F)
Full-opening temperature 95°C (203°F)
Old Jan 22, 2007 | 04:43 PM
jzrx8's Avatar
how can i post pics in here?
Old Jan 22, 2007 | 06:49 PM
LostAngel's Avatar
The thing is, I just purchased an OBD-2 CAN SCAN tool from www.obdcscan.net. I am looking for Enhanced PID numbers (through a VB program, I would send a series of characters to the pcm...and receive data back. That's what I need.
Old Jan 22, 2007 | 08:55 PM
jzrx8's Avatar
give me a list of the PIDS you want and ill see what i can do.
Old Jan 23, 2007 | 06:22 AM
LostAngel's Avatar
I'd honestly like to see all PIDS...
-RPM
-Speed
-Current Gear
-Various Temps
-Tire Pressure
-Throttle Position
-Air/Fuel ratio
Those are to start with...
Old Jan 23, 2007 | 11:55 AM
zoom44's Avatar
you want what you need the tool to send in order to get that info?
http://en.wikipedia.org/wiki/OBD-II_PIDs
if what you want inst ther (certain mazda specific pids) then you'll need to get chummy with hymee or sco. i dotn have that "depth" of info.
doesnt your scanner do this already? or is it just the mazda specific ones you need?
Old Jan 23, 2007 | 12:07 PM
LostAngel's Avatar
Yes, I need the codes to send the PCM to get the enhanced mazda specific pids.
I PM'd hymee but he hasn't been online for a few days.
Old Jan 23, 2007 | 12:30 PM
zoom44's Avatar
goto the performance design australia website and email the contact from there. or try sco on pm here
http://www.performancedesign.com.au/?content=scanalyser
Old Jan 23, 2007 | 12:43 PM
LostAngel's Avatar
I tried emailing, but kept getting bounced replies. I just pm'd sco though.
Thank you!
Old Jan 23, 2007 | 03:31 PM
jzrx8's Avatar
if you have a universal scan tool then you wont be able to receive mazda specific PIDS with it. You need a special scan tool for that(WDS). if you have that then there will be a listing of the PIDS availible stored in the scan tool for you to select from. If this isnt what your talking about then be more specific.
Old Jan 23, 2007 | 03:45 PM
LostAngel's Avatar
I do have a CANScan tool...that can in fact get the mazda specific PIDS...the problem is though I need to know what strings to send to the PCM to get the information.
Old Jan 23, 2007 | 04:02 PM
jzrx8's Avatar
cant you just call the company you bought it from?
czr
Sep 13, 2015 11:37 AM
erikcamacho15
Sep 12, 2015 11:23 AM
