Aftermarket clutch bracket/assembly?
Old Jan 21, 2007 | 09:26 PM
seikx8's Avatar
Is this title ok?
To make the story short, I'm seeking to replace the clutch bracket with a stronger one. After having ACT clutch for a couple of months, the bracket finally gave up.
Does anyone know if there is any source out there that might be making one or offer one soon? If so, I rather wait than purchasing the EOM one which I have no doubt it will brake again with the setup I had.
I'll just let these pictures speak themselves:
I know there are forums member had broken bracket, but didn't find any source that mention if there are any stronger bracket replacement.
If there isn't any, I guess I will have no choice but to weld some re-enforcing metal to the bracket when I replace the new one.
Thanks,
Seik
Attached Thumbnails Aftermarket clutch bracket/assembly?-clutchbracket.jpg   Aftermarket clutch bracket/assembly?-clutchbracket1.jpg   Aftermarket clutch bracket/assembly?-clutchbracket2.jpg
Old Jan 22, 2007 | 02:52 AM
yea,
charles broke one.. warranty covered it. not sure if it was the same area..
i would if under warranty get a new one, and see if they would let you mod it before it went in..j
Thanks,
Seik
Old Apr 8, 2007 | 12:31 PM
expo1's Avatar
He's as bad as Can
Charles, can the average person change the bracket themselves? I am going to hit 90,000 miles next week and about two months ago had a ACT clutch installed. So far no issues but should mine break I am on my own.
Old Apr 8, 2007 | 05:34 PM
seikx8's Avatar
Is this title ok?
Good to hear. My newly replaced assembly already start to show some sign of deformation after 7.5k when I took out to inspect last time and it has been sitting in my garage waiting to be re-enforce, whenever that is.
I would highly recommend anyone with aftermarket plate jump in to reserve one and it will be worth every pennies; As the metal from the OEM bracket is too thin and it's not track worthy at all if you have upgraded pressure plate. And I had hope mazda would change the bracket design, since the tech I ordered from give me a different part # from the print out I had, but it wasn't any different when I got it
Charles, If you happen to complete the modification before I have a chance to work on it, I will get one from you. I have an extra pedal + the newly replaced assembly to trade in as my only progress so far is just some mockup and metal laying around, and my car is just sitting in my driveway collecting dusk
Old Apr 8, 2007 | 10:54 PM
Im going to crawl in my car tomorrow morning to make sure that mine still working fine. I need to do oil change anyway.
Old Apr 9, 2007 | 01:07 AM
grinn253's Avatar
Oh Are El? Why Ya Rly! Thanks for informing us of your agenda tomorrow
Laters!
Edgardo
Old Apr 9, 2007 | 04:36 PM
Laters!
Edgardo
You welcome
and the results :
Its still ok
but it might fail one day. so Charles, Hurry up with your project ! I have my money ready :P
Old Apr 9, 2007 | 04:59 PM
This project, and the Okada coils situation, are my top projects. Even my engine rebuild is not tops on my list.
Something wrong with your Engine ? Or you just want to rebuild it to be safe ? (and clean out all the carbon)
Old Apr 9, 2007 | 05:24 PM
8is>enuff's Avatar
Bland
When mine went they replaced it under warranty. I'm not sure if the new bracket is different or my technician hooked me up with a rigged bracket, but it looks different. See pic.
Attached Thumbnails Aftermarket clutch bracket/assembly?-clutch-bracket.jpg
Old Apr 9, 2007 | 06:14 PM
It runs like crap, the compression is iffy, and I want to port it. It may just be a bunch of carbon build-up as I think the seals are getting noisy, too. Whatever. I hammered my engine a bunch in the first year I had it with the nitrous project and, with 50K on it, it could probably use a rebuild, new water pump, and whatever else.
Even the new bracket tends to allow more side movement of the pedal than most people want, and I don't trust it to hold the stress of an h.d. pressure plate. I have heard from a couple people who got the new bracket and it was still wrecked by the h.d. pressure plate.
What are you waiting for ?
Hurry up and give us a product ! :P
Old Apr 10, 2007 | 01:04 AM
i cant wait to see you apv valves..
Old May 8, 2007 | 12:35 PM
Nemesis8's Avatar
Bigus Rotus
Burn the midnight oil man
Old May 8, 2007 | 10:19 PM
Yeah, yeah.... Now that I have sent RG my side plates I can try and spend some time on that clutch bracket. I have the design in my head, which is VERY simple, and I now just need to shop the project. So I know how many I'll need to make I need to know who is interested in a bracket that is a bolt-on support bracket and you might not even need to unplug the switches from the pedal assembly. Just remove the nuts/bolts from the bracket, lower it a bit, slip the support bracket in place, and reinstall the bracket/pedal assembly. Price will be such that don't get rich off this idea. That's reserved for the PPF.
Cant wait :D
what are you going to do about the PPF ?
I know SR has one, they call it Heavy Duty PPF. but no word about what it actually does (lighter? stronger? god knows)
and I think Richard said something about a Ti PPF a LONG while ago ?
Old May 9, 2007 | 08:40 AM
Red Devil's Avatar
Not at the moment, but within the next year I will probably have interest in purchasing all these parts:
Paradox Performance
Custom axles, clutch brackets, ignition coils
I'm guessing the ignition coils will be more robust for FI situations?
Old May 9, 2007 | 12:31 PM
kwescott's Avatar
One ball, corner pocket
interesting read guys. I have 69,000 miles on mine right now...about 6,000 of those with the ACT HD clutch plate. What symptoms will I experience first, with the clutch bracket, or are they just prone to snapping at once.
I read that some of you guys have a sloppy pedal...meaning that it is sloppy from side to side?
Old May 18, 2007 | 12:25 AM
MPG > HP's Avatar
Taking Orders on New Clutch Pedal Bracket
Yeah, yeah.... ....I need to know who is interested in a bracket that is a bolt-on support bracket.....
Definitely interested. Let us know when you have ballpark prices on Ti and/or other material versions, so we can feedback on what we might be willing to pay. Surely looks like a must have!
Old May 18, 2007 | 03:48 AM
^^ lol, like $800 ignition coils
the AutoExe brace would probably prevent this:
Old May 18, 2007 | 04:17 AM
MazdaManiac's Avatar
^^ Yeah - if the brake pedal was the issue.
Old May 18, 2007 | 06:17 AM
That bracket cost 244 something @ japanparts.com .... seems like a solid piece
I hope that CRH's bracket will be cheaper :P
Old May 18, 2007 | 11:50 AM
oh GD I can't be that stupid , this says it best ... Team MM
Old May 23, 2007 | 11:34 AM
Let us know !
Old May 23, 2007 | 01:28 PM
Swwet, 'cause my is clicky.
I always felt the clutch was less than "positive".
I hate the way you can wiggle the pedal left and right. Same goes for the brake.
Old May 23, 2007 | 02:51 PM
Yep. I might pull my assembly tonight just to poke around.
It sure seems like the sheet metal is **** metal.
Old May 23, 2007 | 05:12 PM
mine is clicky as well, I did looked at it , the weld is still holding but, it might just snap off one day.
Maybe I should purposely break it with some *tools*, and have some dealership to replace it, so I can get your bracket whenever is ready
Old May 24, 2007 | 01:14 PM
Ti is a waste of money on a part that doesn't need the strength and isn't visible.
I'd do it in billet aluminum.
