Engine Coolant
Old Jan 21, 2007 | 07:38 PM
pyro's Avatar
Bui Eh Bui Liu Liu...
Engine Coolant
I checked the coolant level yesterday and found that it is at the L mark when the engine is cold. But when I check the coolant level again when the engine is warmed up, the coolant level is between the F and L mark. So do I take reference when the engine is cold or warmed up? If I need to take reference when the engine is cold, that means I'll have to top up distilled water to near F mark rite? Btw...my 8 is only 4 mths old...is this normal?
Old Jan 21, 2007 | 07:50 PM
Zero_Rotary's Avatar
Double 8
take reference when the engine is cold...so just top it up
Old Jan 21, 2007 | 07:58 PM
lennon's Avatar
Normally the coolant will reach a stable level where if you keep on adding it, it still will reduced.......
Old Jan 21, 2007 | 08:31 PM
CoupeM's Avatar
Night Rider
Mine is at the F mark when cold. So u definitely need to top up or get ur dealer workshop to do it for you.
Old Jan 21, 2007 | 09:14 PM
pyro's Avatar
Mine is PI...so I cannot get the FL22 coolant. But at this stage, I can saftely add distilled water to the F mark rite? Would the ratio of the coolant and water be off?
Old Jan 21, 2007 | 09:32 PM
pyro's Avatar
I read from the forum that coolant leaking to the engine will cause white exhaust smoke...I see some white smoke coming from the exhaust. Is this normal? I cannot comprehen that a 4 mth old car's coolant is at low now.
Old Jan 21, 2007 | 09:49 PM
Double 8
you mean white smoke when you 1st start up the car or even when after the car been warm up and brought out?
if it gives out white smoke all the time, you should bring it back to your PI dealer...4mths old should still be under PI warranty
Old Jan 21, 2007 | 10:25 PM
lennon's Avatar
White smoke = burnt engine oil....
Old Jan 21, 2007 | 11:26 PM
pyro's Avatar
Hmm...it seems like it only happen in the morning or when the engine is cold. I'll try monitoring.
Old Jan 22, 2007 | 12:55 AM
Double 8
if only in the morning then its normal ...not unless its always giving out white smoke all the time...just top up the coolant and monitor it every once in a while
Old Jan 22, 2007 | 01:03 AM
Double 8
i tot white smoke is burning engine oil+coolant?
Old Jan 22, 2007 | 10:52 AM
mkl22's Avatar
when the exhaust pipes are cold you get water vapour. it shows that there is complete combustion. the reason why it only happens when the engine is cold is due to the exhaust pipes are cold as well that is why you can see vapors coming out, when the whole exhaust pipes heats up to super hot, the vapors are really very tiny vapor droplets that you can no longer see.
Anyway just add watoson's distilled water to bring the level up. I still have half a 1.8L bottle with me. just topped mine up and drank some water, thats why half left. haha.
Old Jan 22, 2007 | 05:19 PM
pyro's Avatar
Thanks to all who have replied. I added some distilled water yesterday and high rev it to 7k rpm a couple of times...and I saw black stuff shooting out of the exhaust! Man...the water that came out from there was black....
Old Jan 22, 2007 | 06:49 PM
lennon's Avatar
Very simple...... Just burn a small amount of oil and see!!!!! If coolant can get to your combustion or exhaust, better start to rebuilt your engine becos water seal was broken....
Old Jan 22, 2007 | 06:54 PM
lennon's Avatar
Sometimes it's becos of slight flooding in engine, so you'll see white smoke during the start up....... As long as it's not 'beh yan' all the way, it's alright...
Old Jan 22, 2007 | 07:04 PM
mkl22's Avatar
thats fine. there is prob some amount of soot in the pipe as the renesis is rather rich in Air fuel ratio.
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
MarkX
Jul 31, 2015 07:50 AM
dmac1961
Jul 24, 2015 11:27 AM
