Spark plugs for CHEAP!
Old Jan 21, 2007 | 06:04 PM
AdRoCK3217's Avatar
Rotary Superstar
Ok, I searched around for about an hour, and couldn't find ANY information on getting the OE Iridium plugs for cheaper than the $52 Mazda, Racing Beat, and Mazdatrix charge!
So I found some! Advance Auto Parts!
http://www.partsamerica.com/ProductD...pe=960&ptset=A
Just thought I'd share in case people didn't know, they also have the trailings!
Old Jan 21, 2007 | 06:21 PM
mysql101's Avatar
I use the rx7 plugs. ~$7 each.
Old Jan 21, 2007 | 06:41 PM
lurch519's Avatar
www.evoperform.com
thats still too expensive
you can get em from www.sparkplugs.com at 20 each, or you can get upgraded iridium plugs for something like 35.50 each.
Old Jan 21, 2007 | 06:51 PM
BlueRenesis82's Avatar
Registered Tracker
rx7 plugs for the win
Old Jan 21, 2007 | 06:52 PM
mysql101's Avatar
they don't last as long. they'll burn out in half the time of the stocks, but unless you can get stock plugs for $14 or less, it is worth it.
Old Jan 21, 2007 | 07:02 PM
AdRoCK3217's Avatar
Rotary Superstar
I know they can be found cheaper elsewhere.. (rx7store.net, rx7.com) it's just that..theres an Advance Auto around every corner Worth while to know!
Old Jan 21, 2007 | 07:06 PM
Punksux's Avatar
I thought the stock plugs which are the ones for 20 where iridium plugs?
Old Jan 21, 2007 | 07:33 PM
lurch519's Avatar
www.evoperform.com
nope platinum
Old Jan 21, 2007 | 07:38 PM
AdRoCK3217's Avatar
Rotary Superstar
Wha? Those show the Iridium's being 35.50, what are you talking about $20?
The stock plugs are Iridium.
Old Jan 21, 2007 | 08:01 PM
lurch519's Avatar
www.evoperform.com
i apologize, they do have an iridium electrode. but that price is still too high for the plugs.
the stock spark plugs are part number RE7CL for the leading and RE9BT for the trailing. they are an NGK plug, platinum series. these are the OEM (original equipment manufacturer) plugs, which are the same exact plugs that if you went to mazda and purchased them, would cost 70 to 80 a plug.
Old Jan 21, 2007 | 08:23 PM
Good to know it's available locally.
Old Jan 21, 2007 | 10:57 PM
Fanman's Avatar
Stay away from the Densos. I tried a set in my car, and it ran a bit rougher. Switched back to the NGK's and the coarseness went away.
Old Jan 21, 2007 | 11:11 PM
prescriptionmazda's Avatar
FULL FRONTAL ...downforce
How much life are you guys squeezing from your stock plugs?
just wondered when to expect another purchase.
Old Jan 21, 2007 | 11:17 PM
What upgraded Iridium plugs ? Stock plugs ARE Iridium, NGK Premium Series Plugs, got myself a set of them 2 weeks ago.
I got all 4 80 bucks shipped. Not too bad of a deal.
Attached Thumbnails Spark plugs for CHEAP!-dsc00494.jpg   Spark plugs for CHEAP!-dsc00495.jpg
Old Jan 21, 2007 | 11:19 PM
They're nowhere near *cheap* thats freaking expensive.
I got them 80 bucks shipped, all 4. If I dig deeper I can probably find something a bit lower, but oh well I was a bit lazy.
Old Jan 21, 2007 | 11:23 PM
Expect about 20K miles of *trouble free* driving. If your car had older flahes like 04 and some early 05s. I suggest you to change it to something else (Rx7 or stock 8 plugs) as early as 15K.
Dealer changed my plugs about a year ago for TSB, not sure if its all 4 or just leading, forgot to ask. Im just going to change it all myself tomorrow(I hope)
Old Jan 22, 2007 | 12:18 AM
lurch519's Avatar
www.evoperform.com
i guess i have to quote myself so here goes
Old Jan 22, 2007 | 10:53 AM
when I first read the thread it wasnt up to your reply yet.
Old Jan 22, 2007 | 01:19 PM
So, if I go with the rx-7 type spark plugs, for my change in about 5k miles, I will need to replace those every 10k miles instead of the stock ones at 20k?
Old Jan 22, 2007 | 01:27 PM
mysql101's Avatar
You should be able to do 30k on the stock plugs. 15k range for the rx7's.
Old Jan 22, 2007 | 01:44 PM
ZoomZoomH's Avatar
Mulligan User
^concurs
had my plugs replaced around 30k as part of the reflash recall/battery-starter TSB, car still runs fine at 50k, probably will wait til 60k to get new set
Old Jan 22, 2007 | 02:38 PM
Sounds good, I figure at about 25k miles I am going to get new tires, new plugs, and probably a new intake.
Old Jan 22, 2007 | 04:03 PM
AdRoCK3217's Avatar
Rotary Superstar
80 bucks shipped
So, why did you make that comment, again?
Old Nov 14, 2007 | 05:32 PM
elysium19's Avatar
There are at least 5 websites that have them, each plug is between about $20 and $22, with free shipping. So with any of these sites you can get the whole set for less than $85 shipped.
www.thepartsbin.com
www.sparkplugs.com ($8 shipping, so total is ~$89)
www.autohausaz.com
www.autopartsgiant.com
and probably many more...
Old Nov 14, 2007 | 05:35 PM
mysql101's Avatar
I change my plugs once a year, even if there are no issues. Same for transmission fluid ...
