Searching and Rotarygod are awesome
Old Jan 20, 2007 | 09:47 AM
romycha1's Avatar
Just like the many others, I flooded my car earlier this week. I didn't know if it was flooded or not, but after I searched around a bit I figured that's what it was. I kept finding threads about deflooding, but it wasn't totally clear on how the procedure was done, so after many many tries it didn't work. I finally found a thread where Rotarygod says pull-starting the car Always gets a flooded car started. Well after many attempts on just push-starting it, I finally talk someone into towing me, so I can try a pull-start. First time down the road and the car started up right away ... it was sputtering at first, but that all cleared up after a few seconds.
So for everyone else that gets flooded, don't get it towed. Just find someone to pull-start you.
Old Jan 20, 2007 | 10:09 AM
StealthTL's Avatar
Metatron
Cool Agreed.....
I found this out when I had an RX-3, had to pull start it a couple of times.
S
Old Jan 20, 2007 | 11:15 AM
Cody Red's Avatar
always filling [the c]up
Thanks for the info. I'm agreeing with the title of your post.
-Cody
Old Jan 20, 2007 | 12:17 PM
Punksux's Avatar
I have never done a push start on a car, how fast do you think you would need to get the car to be able to start it. 5, 10, 15 mph?
Old Jan 20, 2007 | 12:21 PM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
Please give details on your pull start method - what gear were you in when the pull started, what gear when igniton key was turned? How long before you tried to start it? Speed? any details good!
Old Jan 20, 2007 | 12:28 PM
Raptor2k's Avatar
Club Marbles Member
details por favor
although my 8 is unfloodable
Old Jan 20, 2007 | 01:23 PM
CTrx8's Avatar
space for rent
Originally Posted by Raptor2k
details por favor
shhh....the rotary gods might hear you.
Old Jan 20, 2007 | 01:35 PM
rotarygod's Avatar
Woohoo I'm a celebrity!!!
2nd gear is preferred. You don't need to get moving very fast. It might only be a couple of miles an hour or so for just a second or it might be 15 mph for a few blocks. Get the car moving before you let out the clutch. Don't just try to get moving with the car in gear and the engine turning. Just ease off the clutch and let it spin. Usually it'll start right up but sometimes it takes a few seconds. You may or may not need to give it some gas pedal. I have even started up engines with a broken apex seal this way! You just need to get them moving faster.
Old Jan 20, 2007 | 01:52 PM
Raptor2k's Avatar
Club Marbles Member
I think they're the reason for my lack of rotary-related troubles. I've sacrificed many pistons for them.
Old Jan 20, 2007 | 01:54 PM
Raptor2k's Avatar
Club Marbles Member
Ah, that explains uncomfirmed private message I sent you almost a year ago...
Old Jan 20, 2007 | 03:01 PM
rotarygod's Avatar
You sent me a PM and I didn't reply?
Old Jan 20, 2007 | 03:54 PM
romycha1's Avatar
I was going maybe about 15-20 miles an hour... Keys were in the ignition in the "on" position, and I was in neutral till we got up to speed then I put it in 2nd gear, obviously with the clutch down. I slowly let off the clutch so the car wouldn't jump. The whole time I had my friend who was towing me on the phone so he knew what I was doing.
When I let off the clutch it jerked a little, but I couldn't tell if the car was on or not, so I put it neutral and tried to rev it. Sure enough, the car was on, and it was sputtering like a son of a bitch. But after a couple of seconds it all cleared up.
Old Jan 20, 2007 | 05:44 PM
refugeefrompistons's Avatar
doing this in reserve ok? i want 2 noe if i can juss fall bakwards out of my driveway
Old Jan 20, 2007 | 06:12 PM
rotarygod's Avatar
Yes I have done it in reverse as well. The only thing that matters is that you've got the engine turning.
Old Jan 20, 2007 | 06:18 PM
Raptor2k's Avatar
Club Marbles Member
Yeah, March of last year, still an uncomfirmed receipt. It's cool
Old Jan 20, 2007 | 06:46 PM
dmc27's Avatar
doin' the bull dance
meh. I think they're both overrated.
[runs away laughing maniacally]
Old Jan 20, 2007 | 10:12 PM
romycha1's Avatar
You know.. that was the very first thing we tried since I was on a small incline. It didn't work, I guess cause the incline wasn't steep enough.
Old Jan 20, 2007 | 10:58 PM
Frynge's Avatar
Mad Scientist
yes...praise your rotarygod and sacrifice him many virgins and pistons! XD
Old Jan 22, 2007 | 02:26 AM
it is a distance thing..
Old Jan 22, 2007 | 09:31 AM
rotarygod's Avatar
I don't mind wasting the pistons but let's be real here!
Old Jan 22, 2007 | 09:47 AM
RX8THELAW's Avatar
next time just pull the fuse for the fuel pump & start it then put it back in and try to start it again
Old Jan 22, 2007 | 10:44 AM
jird20's Avatar
Mad for a Furai
I believe this (pull start) can work, and it definetly works as some members of this forum have achieved successful results.
Now my point here is: I read in the owners manual (Euro version) that you should never do a pull start. The manual does not say why.
I imagine that that could be related to cat issues (pretrol afterburning inside the cat once you get the engine started). Does anyone know the real reason behing that Mazda Warning?
Cheers
jird20
Old Jan 22, 2007 | 11:13 AM
dmc27's Avatar
^ not 100% sure, but I'd wager it's an "Idiot Note", since it can be dangerous if done by an idiot.
The manual also states in several places that the engine should not be shut off while driving, and you should never adjust the seat while driving.
Kind of like the "no turn" signs on highway on ramps.
Old Jan 22, 2007 | 10:47 PM
romycha1's Avatar
Cheers
jird20
Again... I read another post that Rotarygod talked about this (I'm kinda starting to feel like a suckup)... I believe he said something along the lines that the owners manual says a lot of things you're not suppose to do..... yadda yadda yadda.... I don't really remember the rest.
Maybe he'll chime in here and reitterate.
Old Jan 22, 2007 | 11:27 PM
rotarygod's Avatar
The owners manual pretty much states to use only genuine Mazda parts and have only trained Mazda service centers work on your car. That pretty much rules out using any aftermarket products of any kind including intakes, exhausts, etc. We all know everyone obeys those rules too!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
Evan Gray
Sep 26, 2015 12:30 PM
