help on rear wheel fit!
Old Jan 18, 2007 | 12:43 PM
llzjayarzll's Avatar
meow
axis shine rear wheels
19x9.5 40mm
5x114.3
http://wheelstudio.com/catalog/images/axis/shine.jpg
im not really good at figuring it out but ive read some threads before and it said to roll my fenders?
anyone help =/
tire reccomendations?
yes they will be a staggered fit.
Old Jan 18, 2007 | 12:48 PM
TownDrunk's Avatar
I am a meat popcicle
You're basically moving the edge of your tire out about 29mm toward your fender edge. If my memory serves me right, 28mm would be the outer edge of the fender well for the rear.
Old Jan 18, 2007 | 11:07 PM
it depends on what size tire you plan to run, post it
Old Jan 19, 2007 | 04:03 AM
meow
well any suggestions?
Old Jan 19, 2007 | 07:10 PM
I have a suggestion, since it will depend on which tire size you plan to use you might want to post it
a 9.5 with 265/35-18 Yoko Advan Neova fits with a 45mm offset, it rubs the lip with a 38mm offset, that particular tire runs a bit wide for it's specified sizing
I don't see a 10.5 not rubbing at that offset unless the fender lip is at least rolled flat, or it uses a very narrow tire, or the ride height is jacked up ...
Old Jan 19, 2007 | 09:32 PM
NgoRX8's Avatar
with The Team on this one. lol running a tire size like others do here mostly 275/30/19, you will rub. a smaller tire might solve the problem or u can just roll or shave ur fender.
Old Mar 10, 2007 | 11:26 PM
meow
no rubbing at all.
i was kinda confused after talking to 3 different people with diff backgrounds on it. decided to go with the hubcap store owner dude who consulted his distributor. running 275s on rears and no rubbing pretty much at all. and he also said i was running the minimum on offsets. lucky me i guess huh.
Old Mar 10, 2007 | 11:27 PM
meow
yea i know, too much chrome. im most likely going to take off my gas cover and def taking off the handles =/
Old Mar 12, 2007 | 11:18 AM
Tanaka826's Avatar
loooks nice with the ms kit..
Old Mar 12, 2007 | 11:23 AM
TownDrunk's Avatar
Look nice! Great choice.
Old Mar 29, 2007 | 08:09 AM
ArmyOfOne's Avatar
Were you able to keep your TPMS on these rims? Not that it really matters but inquiring minds want to know.
Old Mar 29, 2007 | 09:02 AM
meow
nope. im gonna sell them with the stockers cuz im not going to drive it in the winter anyway.
yes the tpms light is always on but theres a DIY where you can take it off permanently. you gotta cut a wire basically.
Old Mar 29, 2007 | 11:52 AM
not all tires are created equal to their size rating, my 265/25-18 Yoko Advans are wider than any other 275 street tire, your 275 tires look narrow if that's a 9.5" wide wheel, almost looks like the rim lip is wider than the tire, my 265s on a 9.5" wheel have a nice bulge past the wheel lip
that's why I tried to get you to post your tire info
Old Mar 30, 2007 | 09:04 AM
meow
you think i can drop my car a bit? or would that require shaving/rolling.
oh yea btw i got new vs sides =/
Old Mar 1, 2009 | 05:39 PM
BlackStar04's Avatar
I'm looking at doing a 19x9.5 35mm offset for the rear with a 255/35/19 for the tire. Does anyone think i will have a problem with rubbing and will I have to roll my fenders? I am thinking i am going to have to. But, i figured i would ask anyways. Does anyone think that the tire would be sticking out of the wheel well? I would like it to be as close to flush as possible. But, if its out or in a little bit i wouldn't mind it. thanks for any info back
Last edited by BlackStar04; Mar 1, 2009 at 05:41 PM. Reason: adding more questions
Old Mar 1, 2009 | 05:41 PM
Bunique's Avatar
Ground Assault
check the "will it fit" thread in the wheels and suspension section. It seems though that you will be very close and will most likely need to get ur fenders rolled
Old Mar 1, 2009 | 06:02 PM
Thanks....I've looked at your car quite a bit. what is the offset for your wheels? I know that your wheels are .5" bigger in the back.
Old Mar 1, 2009 | 06:43 PM
Bunique's Avatar
Ground Assault
mine are 19x10 with a 45 offset with 275/35 T1R's and 19x8 with a 45 offset in the front with 235/30's
WingleBeast
22
May 23, 2016 09:22 PM
codesterb91
Nov 16, 2015 05:57 PM
Kahl
Aug 20, 2015 11:49 PM
Mr.Durden
Aug 12, 2015 02:21 PM
Brandonien
Jul 30, 2015 12:33 PM
