Knocking sound???
Old Jan 17, 2007 | 11:11 PM
youngen's Avatar
Knocking sound???
My car is making a knocking sound from the engine bay what sounds like on the left side if looking at the car from the front. any clue on what it is and how to fix it?
Old Jan 18, 2007 | 04:55 PM
fullsmoke's Avatar
Anatomy of a corner...
When does it happen? What causes it to happen?
FS
Old Jan 18, 2007 | 06:59 PM
youngen's Avatar
like as soon as i turn the car on and in all gears you can hear it knocking and as i speed up or rev the engine u can hear it too
Old Jan 18, 2007 | 07:25 PM
otherside's Avatar
I dont care...
Its probably your tpms sensor rolling around in the tire
Old Jan 18, 2007 | 07:50 PM
Duke15's Avatar
2006 Velocity Red Mica
is it low on oil?
Old Jan 18, 2007 | 09:28 PM
Clavius's Avatar
Its all about Style...
Does it increase when you speed up or stay the same? also I hope you checked your engine while on under the hood to see if anything is loose. If its more of a clicking noise you might just have a pebble stuck between your brakes and tires (happened to me a few times annoying as hell but a quick left right turning of the wheels over a bump does the trick to free the pebble.)
Old Jan 19, 2007 | 02:04 AM
nice, point your toes, dismount.
Old Jan 19, 2007 | 12:01 PM
youngen's Avatar
the sound is comming from what is to be the top of the headers anyclues?
Old Jan 19, 2007 | 12:08 PM
dynamho's Avatar
Do you hear it only when the car is moving? Or do you hear it when the car is stationary with the engine running? Or both?
Old Jan 19, 2007 | 12:24 PM
youngen's Avatar
both
Old Jan 19, 2007 | 12:32 PM
youngen's Avatar
Old Jan 19, 2007 | 05:41 PM
youngen's Avatar
up up up
Old Jan 19, 2007 | 05:59 PM
9G Redline's Avatar
Trolling since 2004
I'm having a similar problem. I couldn't reproduce it for the Mazda techs. Mine only happens at idle. Sometimes when the car's cold and sometimes when the car's warm. It comes and goes. Starting to drive me crazy quite frankly. My sounds coming from the same area highlighted in the picture. Sounds like it's coming from the intake somewhere down on the side of the motor.
Old Jan 19, 2007 | 06:03 PM
otherside's Avatar
I dont care...
Man that is wierd to see the brake booster on the other side!
mysql101's Avatar
air pump? ssv?
Old Jan 19, 2007 | 06:33 PM
youngen's Avatar
so does anybody have a clue because this has to to be the most annoying sound.
Old Jan 19, 2007 | 07:40 PM
Easy_E1's Avatar
What are you doing in Houston with a right hand drive car?
Old Jan 19, 2007 | 07:46 PM
youngen's Avatar
I just found a pic and circled the spot were thesound was coming from. and what wrong with aright hand drive car in houston?
Old Jan 19, 2007 | 07:50 PM
Easy_E1's Avatar
NOthing wrong don't get excited. Just curious.
I am thinking it might be the air pump. Can you here the noise with the hood up?
See the black round thing on a black plate to the left and down a hair? That is the air pump.
Check it out.
It's right on the edge (left) of the pic above the strut bar.
Old Jan 20, 2007 | 02:41 AM
youngen's Avatar
yah u can heat it with the hood up. i don't think its that because i toll a screwdriver and put it to my ear and i was getting the most vibrations/sounds from the circled part in the pic.
Old Jan 20, 2007 | 02:50 AM
chris,
you have an 04 correct... is it an auto or 6speed. how many miles are on it???
what mods have been done if any? is it rhd or lhd? i know it is just a pic but the more info the better...
does the knock increase with engine rpm or stay the same?
does the knock change if you put the clutch in or out?
Old Jan 20, 2007 | 11:18 AM
youngen's Avatar
its a 2004 auto 65,000 miles its dropped on tein sprints, and has 18x7.5 rims wrapped in kuhmo Exsta 245/45/18's it lhd, when i acceleratre or rev the sounds stays the same but jsut goes faster and in park or all gears u can hear it sound doesn't change pitch it literally sounds like there is a "rock bouncing around in therE"
Old Jan 20, 2007 | 05:10 PM
youngen's Avatar
its not the airpump but know ther eis hardly even a sound like its going away. this is weird.
Old Apr 29, 2007 | 10:30 PM
dova's Avatar
where you able to fix the noise?
Old Apr 30, 2007 | 12:08 AM
donack456's Avatar
Younggen didn't your engine burn up. Is this the new engine knocking??
Younggen didn't your engine burn up. Is this the new engine knocking? Theres no tapins to lift the pistons so I don't know. Could be some kind of carbon build I had that happen to 1973 Cadillac I owned back in 1979. I ran some engine flush through it and gunned the engine after and drove it about 30 miles on ther expressway, it stopped and I drove it for another 4 years.
Take it back to your Mazda dealership. Hopefully they can hear it and fix it.
