Misfiring all the way?... -_-^
Old Jan 15, 2007 | 10:31 AM
brokenhelmet's Avatar
Exclamation Misfiring all the way?... -_-^
Got ma white 8 last year... around summer...
have MS CAI, highflow CAT, Greddy Exhaust..
went to track and got CEL..checked it by my OBD and
P0302.. the second cylinder(rear rotor) misfiring came up...
at the time I was on the track, I had new spark plugs and plug wire..
about a month ago, I got new coils which is for '06 models...
still got CEL on the highway..
So.. I have my spark plugs changed, plug wire changed and coils changed..
well... one thing I found out how to get CEL on my odometer...
if you press and depress your gaspedal in 3rd gear with around 7500RPM...
you'll get one...
I found this out because of exhaust, I can hear that bogging sound
when I depress the gaspedal rapidly while cruising in more than 6000RPM in
wherever the gear is.....
anyone solved problem?..
should I change my battery?.. or what?...
I mean.. I know that some of you might tell me to use "search"...but..
Everyone has different solutions, so I think we might have to sum it up
and get one definite solution to solve that F$#%ing "RANDOM MISFIRE"...
anyone?
Old Jan 16, 2007 | 12:52 AM
If its so *Easy* to make your car misfire then ....
make an appointment with ur dealer
Just before you bring ur car in, PUMP the crap outa ur car to make the CEL show .... leave the car there and let them handle the issues.
duh
Old Jan 16, 2007 | 02:48 AM
how much gas was in the tank?
Old Jan 16, 2007 | 02:54 AM
just found this from you pm, give me a bit i will try to sum it up for you. btw, what were you doing in koera???
Old Jan 16, 2007 | 03:04 AM
the reason i asked about the fuel level. is i have several times got that code on a high speed run.. that to me means ~10mph to ~142mph.. everytime it happened i was at less than .25 of a tank..
this will tie in at the end of this post.....
normal reasons to get the code / flashing cel.
in order of how often it happens..
dirty plugs
loose plug wires
bad plug wires
coils going bad
a coil gone bad
more than one coil gone bad.
dirty fuel inj
unreset eshaft
and the other that relates to fuel... here is a link to read about it.. sounds like you might be in the first stages of it...
https://www.rx8club.com/showthread.p...ight=fuel+pump
also related to this i have read about a bad fuel pump connector that caused the same thing...
there will never be one answer for this..
Old Jan 16, 2007 | 03:57 AM
I'm going to Purdue... since '05...
and... came to Korea just for visit.. cuz it's my home country...
will go back in two to three month...
how did you know I'm in Korea..
Old Jan 16, 2007 | 03:58 AM
Miss my car back in Indiana....
it's in garage for now...
by the way...
I never drove under 1/3 of fuel...
cuz I heard about that 1/4 fuel thingy from my buddy who used to be FD owner...
Old Jan 16, 2007 | 04:00 AM
I saw this..
clutch thing...
https://www.rx8club.com/showthread.p...ight=misfiring
Old Jan 16, 2007 | 04:03 AM
Also.. I'm not sure if it's cuz of cold weather of Indiana...but...
the car kinda having some hard time to start...;;
Old Jan 16, 2007 | 04:06 AM
i had a visit there.
nice place.. lush..
i research before i post.
Old Jan 16, 2007 | 04:09 AM
thnx..haha...
hmm...so...
you mean... one of the reason for misfire that
many 8 owners having problem with is Fuel Pump... rite?
Old Jan 16, 2007 | 04:42 AM
thnx..haha...
hmm...so...
no the problem is very rare. as is the clutch problem that one is one in 100,000.
i think you need to make sure all recalls were done right. this is a problem for the dealer to figure out...
Old Jan 16, 2007 | 04:48 AM
on the highway did you get a solid or flashing cel?
Old Jan 16, 2007 | 04:57 AM
and how did you check for the cel #?
Old Jan 16, 2007 | 01:49 PM
I got it on track at first time...
I checked the code # with my Scan...
and... erased the codes since it was annoying...
but.. after 2 weeks.. I got the flashing CEL on highway again...
and... after 3rd time.. it became solid...
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Aug 21, 2022 01:29 PM
XianUnix
Sep 29, 2015 03:48 PM
Forevermore
Sep 20, 2015 01:04 PM
Irvinb16
Sep 11, 2015 10:27 PM
