Air Pump Noise?
Old Jan 10, 2007 | 07:34 PM
fullsmoke's Avatar
Anatomy of a corner...
Unhappy Air Pump Noise?
On a cold start up, I hear an extremely loud squeal--a very high pitch "chattering" noise that lasts around 20 seconds. I am almost 100% positive that it is my air pump, not a belt or anything else. I searched and most seemed to say that the air pump is failing...
Should I just drop off the car and specifically say that they need to wait for the engine to become cold? I am wondering because if they do not find any problems I will have to pay for the rental they provide.
Any advice would be appreciated!
FS
Old Jan 10, 2007 | 07:51 PM
Marine_RX8's Avatar
The dealership I normally go to waits till the next day to check my car out, and both times after they told me that there was nothing wrong with my transmission, even though it constantly grinds in 5th gear , I didn't have to pay for the rental.
Hope that helps
Old Jan 11, 2007 | 10:10 AM
fullsmoke's Avatar
I am afraid that they will simply state that the loud noise is "normal." Has anyone had their air pump replaced from a dealer (they did not buy the car from) due to noise?
FS
Old Jan 11, 2007 | 04:53 PM
fullsmoke's Avatar
Has anyone had a noisy air pump (excessive noise) and had replacement denied?
Old Jan 12, 2007 | 01:28 PM
dgrx8's Avatar
FN GR8
i've heard the loud screech also in the morning. but, after the latest flashes & over time it just stopped doing it... no explanation really since the flashes didn't touch this subject. but, i do remember it was annoying!
Old Jan 12, 2007 | 01:54 PM
WantedTwo's Avatar
C4 burns real good
I've had the same problem, mine sounded like a dust buster on crack. Its not normal and the dealer replaced mine with out a hitch. Its very easy to replace if you find a used one.
Old Jan 19, 2007 | 04:47 PM
j9fd3s's Avatar
havent seen a bad air pump yet, but its very simple to diagnose, unplug it, and start it cold if the noise is gone, there ya go.
Old Jan 24, 2007 | 10:13 AM
TALAN7's Avatar
Huw much does an air pump cost?
Old Jan 24, 2007 | 10:22 AM
TALAN7's Avatar
or an oil pump for that matter.
Old Jan 24, 2007 | 11:02 AM
jzrx8's Avatar
Drive Like You Stole It
Part OEM Part Price
Air Injection Pump
A.I.R. Pump N3H11381XC $413.80
A.I.R. Pipe N3H113820B $104.30
Labor to Replace (Air Injection Pump)
Level Mfg. Warranty (0.3 hours) Standard (0.4 hours)
Old Jan 24, 2007 | 11:43 AM
TALAN7's Avatar
Originally Posted by jzrx8
Part OEM Part Price
Air Injection Pump
Thanks again. Hope it's not that.
Old Jan 24, 2007 | 02:00 PM
jzrx8's Avatar
Your welcome and so do I, hopefully its covered under warrenty
Old Jan 24, 2007 | 02:01 PM
TALAN7's Avatar
75,000 miles... nope
Old Jan 24, 2007 | 06:46 PM
Old Rotor's Avatar
I may be mistaken but the emissions warranty is for 100k miles on the 8......is that pump not part of the emissions?
Old Jan 24, 2007 | 06:55 PM
jzrx8's Avatar
The emissions warrenty should be to 100,000 miles and it SHOULD be covered under that.
Old Jan 25, 2007 | 09:30 AM
fullsmoke's Avatar
Yep, ^ they are right. The air pump is part of emissions--go now before you hit 100k.
Old Jul 23, 2007 | 10:33 AM
bcav's Avatar
I have the same issue. My secondary air injection pump is bad. Morrie's Mazda in Minneapolis is denying warranty coverage claiming emissions is only to 80K miles and does not cover the pump. It does sound like this is a common a recurring problem though - especially at higher miles- as my car has 72K miles on it
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Mane
Nov 20, 2015 12:16 PM
