9000 RPMs to move car!! ;-)
Old Jan 9, 2007 | 01:01 AM
Acclaim99's Avatar
Alright, gotta replace the clutch.
This is what I was looking at: (Centerforce Stage 2)
http://www.horsepowerfreaks.com/pric...s/part/Stage_2
How much would installation be around, and is the only part I need?
Old Jan 9, 2007 | 01:28 AM
rotarygod's Avatar
Since I've always installed all of my own parts I'm not too sure what that would cost to install. On my RX-7 (s), I've used the Centerforce Dual Friction clutches. I love them. They work really well and the pedal effort is easy. It's actually quite deceiving. Even the dual friction is light on the foot so you may as well go that route. Mine was actually lighter in pedal effort than my stock RX-7 clutch but it has twice the clamping power. Good stuff. There are many people that don't like Centerforce for some reason but I don't know why. ACT makes some really good clutches too. While you're in there, you may as well replace the flywheel too. It's a noticable mod.
Old Jan 9, 2007 | 09:34 AM
Socr8tes's Avatar
The two Centerforce clutches I've installed on other cars tend to chatter a bit on engagement. I still like them though for the reasons rotarygod states.
Old Jan 9, 2007 | 09:57 AM
(subscribing for future use)
Acclaim: if you don't mind me asking, how many miles did you get out of your stock clutch? Any track days in there or just lots of "spirited" driving?
Old Jan 9, 2007 | 10:01 AM
RX8THELAW's Avatar
ACT is a good unit also or RPS if you want something even stronger
Old Jan 9, 2007 | 10:26 AM
rotarygod's Avatar
The Centerforce do chatter a little bit but that's due to the weights that prodive the "center force". Those weights are obviously subject to inertia which helps the clutch clamp tighter the higher the rpms get. Without the chatter, you'd have no weights. That's a part of the clutch design.
Old Jan 9, 2007 | 11:07 AM
Socr8tes's Avatar
Which is fine if you're willing to make the small compromise for the performance benefit. Like me, I'm guessing the OP probably won't mind. But if anyone's reading this looking for a good replacement for their daily driver, they may find a little chatter following every dead stop to be a little annoying after a while. I have no experience with this clutch on the RX-8 though so it may not even be an issue...
Old Jan 9, 2007 | 01:23 PM
Acclaim99's Avatar
I have 12 track races, lots of spirited driving. Current milage 16,000... about 8000 miles with the turbo.
Old Jan 31, 2007 | 07:34 AM
Acclaim99's Avatar
I switched and got the ACT...
Old Jan 31, 2007 | 09:32 AM
rotarygod's Avatar
That's a good company too.
Old Jan 31, 2007 | 12:23 PM
Design1stCode2nd's Avatar
Well hopefully an average driver with no track days can see at least 50k miles before replacing the clutch. I want to replace the clucth and flywheel at the same time so I want to make sure I have teh cash for it since I have other mods I want to do first.
Old Jan 31, 2007 | 03:30 PM
NoTears316's Avatar
Shock and Awe
I'm just under 50k miles, and still on the original clutch.
Old Jan 31, 2007 | 03:34 PM
Celronx's Avatar
Unregistered User
I'm at 73k and I've had no problems with my clutch.
Jesus Martinez
44
May 6, 2025 08:09 AM
Dokuji
Nov 1, 2016 02:51 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
madrotor
Jul 26, 2015 12:06 PM
Belalnabi
Jul 17, 2015 07:48 PM
