Fan still running - key removed
Old Jan 8, 2007 | 03:16 AM
enforcer's Avatar
Before I get flamed with the standard "use the search feature"
I've searched high and low and can't find anywhere a clear answer on this...
Today being a 'hot' day...35 C (95 F) I had a 2 hour run, and other than the aircon running on fresh and struggling a bit at the lights (which would be normal) returned home and noticed the air-conditioner fan, (or another fan) was continuing to run...after the key was removed from the ignition!
....can anyone please help as to what is happening please? (sorry - relatively new owner here)
Old Jan 8, 2007 | 04:08 AM
enforcer's Avatar
....I just found the page in the manual which makes reference to an electrical cooling fan turning on once the engine reaches a pre-determined temperature.
How normal is this during summer?????
Old Jan 8, 2007 | 05:10 AM
Wilson's Avatar
Peeping over the fence
Very normal.
Old Jan 8, 2007 | 06:02 AM
foo77's Avatar
4th batch : Apr 03'
^ normal for how long? i think mine just turned on more than 15 mins
Old Jan 8, 2007 | 06:12 AM
enforcer's Avatar
Mine was running for over 5 minutes...hence I got a bit worried.
I've just heard of 10 but holy crap....15????
Old Jan 8, 2007 | 06:15 AM
BoosTED's Avatar
Mine hasn't turned on for that long but I rarely kick the air conditioning on, unless it is in the 90s fahrenheit.
It does come on after the car is off, if the engine is reading high temperatures after driving.
Have you checked you coolant lately?
Do you have forced induction?
Old Jan 8, 2007 | 06:23 AM
foo77's Avatar
4th batch : Apr 03'
mine just NA and the coolant still at F level..so i just put it in ignition ON,than it just stop
Old Jan 8, 2007 | 06:26 AM
Wilson's Avatar
If it is hot outside, it will run for a few minutes. I never timed it.
Old Jan 8, 2007 | 06:50 AM
foo77's Avatar
4th batch : Apr 03'
guess mine's probably too hot
Old Jan 8, 2007 | 07:18 AM
Easy_E1's Avatar
Try living in Arizona in the summer. 120+ degree's. My fan stays on for what seems an eternity. And yes it is normal.
Old Jan 8, 2007 | 07:38 AM
foo77's Avatar
4th batch : Apr 03'
thanks,now i feel better
drebbrnator
Dec 27, 2018 07:02 PM
rotorocks
47
May 11, 2016 03:23 PM
Nisaja
Aug 6, 2015 01:27 AM
ironj221
Jul 16, 2015 10:16 PM
