Replacing Front Grille
Old Jan 7, 2007 | 11:24 PM
BigAAA's Avatar
A few weeks ago I rear ended someone and broke my grille. Didn't do any other damage, but I did need a new grille. I just got the new grille in, and was wondering if anyone had ever installed the grille. I assumed it would just pop into place, but it looks way more complicated. If anyone has any pictures of what I need to do (which bolts to take off...) please let me know. Thanks.
Old Jan 8, 2007 | 11:28 AM
willhave8's Avatar
Pretty sure you have to take off the front fascia - pretty easy though... Here are the written instructions but you need pictures. Try searching here and the Racing Beat site using "REVi install" Once you have the fascia off, changing the mesh grille should be easy. 90 minutes and your done...
Found a good link to help you.
https://www.rx8club.com/showthread.p...bumper+removal
Old Jan 8, 2007 | 11:30 AM
Go48's Avatar
You will likely have to remove the front bumper cover, because the grille bolts in from the inside. Alternatively, you may be able to remove the underbody pan and get to it that way, but that's probably more difficult than removing the bumper cover.
For information on removing the bumper cover, check out the DIY (in the DIY section, of course) having to do with installing protective screens in front of the A/C condensor and oil coolers. I think there are instructions there on how to remove the bumper cover.
EDIT: Here's a thread that will help:
https://www.rx8club.com/showthread.php?t=10941.html
Old Jan 8, 2007 | 11:41 AM
willhave8's Avatar
Wink
You got me by 3 minutes... Geesh, I thought I had this one...
Old Jan 8, 2007 | 05:24 PM
Go48's Avatar
Yeah, but I had to do an Edit so you win anyway!
Old Jan 8, 2007 | 06:39 PM
BigAAA's Avatar
wow, thanks for the quick response, i searched for two days and couldn't find a post that good. Maybe I just suck at searching... oh well, thanks anyways.
fullsmoke
Nov 24, 2015 04:09 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
SayDfuse
Aug 3, 2015 10:41 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
