View Full Version : Engine Cover
rx-ache
09-09-2003, 10:42 AM
Does the engine cover serve any useful purpose? Seems to me that with the need to frequently check oil consumption, it is just in the way.
The only thing I could think of that it might do would be to protect the hood from excessive heat. Do you think the paint on the hood might be damaged if it were removed permanently?
Thanks,
rx-ache
mikeb
09-09-2003, 03:08 PM
I dont think the hood paint would get damaged. I think the cover is for looks so If you want to remove it for good I'm sure its ok
dcfc3s
09-09-2003, 04:44 PM
Yeah, it's really just for aesthetics, to make the engine bay cleaner looking.
If you do remove it, please hang on to it! In 10 years, people will be dying to have one :). The battery box lids on 2nd gen RX-7's are usually missing due to incompetent previous owners, and they're not cheap new. It's just a shame when someone misplaces/throws out something like that.
Hell, the 2nd gen turbo RX-7 has a top-mounted intercooler that's ALWAYS in the way for a lot of maintenance things. Unfortunately, you can't pitch it :). But, you do get REALLY good at removing it over time!
Dale
Kawi
09-09-2003, 04:52 PM
Doesn't also aid a little in sound muffling from the engine bay?
Jazzman
09-11-2003, 05:51 PM
Originally posted by mikeb
..I'm sure its ok
Hmm... famous last words.. Well at least he's *sure*. heh
brothervoodoo
09-11-2003, 05:59 PM
I remember reading that the engine cover "may" also assist with airflow.. don't know for sure..
EDIT:
Did a search and found this:
http://www.rx8club.com/showthread.php?s=&threadid=8282&highlight=engine+cover
Seems inconclusive if it's for looks or utility.
mikeb
09-11-2003, 07:46 PM
put it this way, I'm keeping mine on
Digisan
09-11-2003, 08:48 PM
The Mazdaspeed strut tower brace makes it impossible to keep the cover on. If the Mazda engineers don't need it then I think you should be just fine.
Strut tower brace (http://www.i-m-racing.com/mafrsttobrrx.html)
D-san
mikeb
09-12-2003, 12:56 AM
wow 616 bucks
is that worth it
canzoomer
09-13-2003, 12:33 AM
I asked a Mazda Canada rep, and he said it is required for airflow for cooling.
Truth or bullshit, I do not know, but he rather sternly warned me about leaving it off..
Winning_BlueRX8
09-13-2003, 08:37 AM
I was told the same thing by my dealership. The cover aids in airflow and cooling.
OverLOAD
09-17-2003, 12:09 PM
It's definately not for cooling, it's right up against the hood..
I'd remove mine, but I'm pretty sure that it is actually a bit functional. It helps to keep the airbox in place, and also to keep the battery cover in place.
I think the engine looks tons better without it tho, I'm always taking mine off. When I get a new air intake, I'll probably keep the cover off...
OverLOAD
