How much does the Renesis weigh?
Old Jan 2, 2007 | 01:27 PM
Hanzo's Avatar
Question How much does the Renesis weigh?
Wonder how much does the rotary engine weigh compare to a typical 4 cylinder engine like a K20z3. Reason I'm asking is saw info on the Ariel Atom and wonder if it would be lighter using a renesis engine instead of the honda motor.
http://www.automotivearticles.com/12...Atom_USA.shtml
Old Jan 2, 2007 | 02:13 PM
CTrx8's Avatar
space for rent
https://www.rx8club.com/rx-8-discussion-3/renesis-experiment-106010/page2/
check the bottom of this page and the third page. it's being discussed for an MX-5 swap.
Old Jan 2, 2007 | 02:38 PM
Ike's Avatar
Ike
Blue By You
We've been through this a few times and it seems no one really knows for sure. Well, people know but definitive info is difficult to find. Simplest answer is that it's heavier than some 4 cylinders and lighter than others. Dressed it seems to weigh a touch over 300 lbs. which is about 20 lbs. lighter than the F20C that was in the S2K.
Old Jan 2, 2007 | 03:35 PM
9-K Rever's Avatar
Rev Addict
Hmmm....need to find the exact weight.
Old Jan 2, 2007 | 04:21 PM
zoom44's Avatar
naked it weighs 260ish
Old Jan 2, 2007 | 04:25 PM
Ike's Avatar
Ike
Blue By You
That's hot
Old Jan 2, 2007 | 04:44 PM
dtorre's Avatar
Ultimate ****** Goderator
Wow my woman weighs more than that
zoom44's Avatar
or is it 260 dressed? damn i cant remember
Old Jan 2, 2007 | 04:46 PM
zoom44's Avatar
ahh here it is: per Jim Merder at Racing Beat, the fully dressed Renesis engine with all attachments sans airbox weights 267.5lb.
Old Jan 2, 2007 | 05:39 PM
9-K Rever's Avatar
Rev Addict
Thanks!!!
Old Jan 2, 2007 | 08:29 PM
Ike's Avatar
Ike
Blue By You
That seems way low, does that include fluids?
Old Jan 2, 2007 | 08:35 PM
AdRoCK3217's Avatar
Rotary Superstar
Well Ike, these are *kind of* estimates, but also going from memory..
I believe the front + rear irons weigh around 35lb each, with the middle iron weighing about 40lb. The housings are roughly 15-20lb each. Rotors..10-12lb each.
I would expect the fully built shortblock to weigh in at roughly 150lb, assuming that my weights above are rather high. I can pick it up and carry it by myself, with the oil pan removed, but with the flywheel still on...so..
Old Jan 2, 2007 | 08:43 PM
Ike's Avatar
Ike
Blue By You
So where is Babylou getting this info? I've seen similar numbers elsewhere. Lastly, why is Mazda so tightlipped about the weight of the Renesis?
http://www.rx-8forum.com/showpost.ph...0&postcount=21
Old Jan 2, 2007 | 08:44 PM
Ike's Avatar
Ike
Blue By You
You're still missing a lot of things there. It's also important to note that some manufacturers include full exhaust with engine weights while others do not.
Old Jan 2, 2007 | 08:49 PM
AdRoCK3217's Avatar
Rotary Superstar
Some corrections. The rotors weigh approx. 9.2lb each (Source: Racing Beat)
The stock irons weigh roughly 26lb each (Source: Racing Beat, 1993 RX7)
With that knowledge, I would assume the housings are around 10-15lb.
That puts engine weight, with front cover + all gears, oil pump, etc, at around 150lb.
Old Jan 2, 2007 | 08:52 PM
AdRoCK3217's Avatar
Rotary Superstar
Like what? x.x
Apex seals? Oh..ok..set of 6 <.< 1 lb..or less..xD
With all the *big* parts added up (rotors, irons, housings), I got about 126lb. The oil pump + chain weigh about 4lb together. I'd say my 20lb-margin, saying it weighs 150lb in short block form, is plenty to include all seals, springs, gaskets, vaseline, etc.
I do not include full exhaust, because that is not the engine, and would not be swapping into a different car. That is..retarded.
Old Jan 2, 2007 | 08:55 PM
Ike's Avatar
Ike
Blue By You
Here's an interesting link even if it doesn't give us much in the way of answers.
http://wheeltalk.fancal.net/wp-conte...ine_weight.txt
Old Jan 2, 2007 | 08:58 PM
mysql101's Avatar
^ it gives is an idea...
Mazda 12A and 13B 260 (109)
Mazda 10A rotary 224 (20) (Cosmo) (bare)
Mazda 10A rotary 268 (20) (R100) (bare)
Mazda 10A rotary 190 (27) (R100) (without thermal reactor)
Mazda 10A rotary 280 (27) (R100) (with thermal reactor)
Mazda 12A rotary 348 (20) (RX7) (with oil and water)
Mazda 12A rotary 356 (20) (Japanese model turbo, EFI)
Mazda 12A rotary 275 (85) (w/flywheel, t.reactor, no alt.)
Mazda 13A rotary 301 (20) (R130 Lucia - Japan only) (bare)
Mazda 13B race 242 (95) 2-rotor race motor, with accessories
Mazda 13G 3-rotor race 319 (95) 3-rotor race motor, with accessories
Mazda 13J 4-rotor race 396 (95) 4-rotor race motor, with accessories
Mazda 13B FI 337 (197) 1986-1992 160hp (w/oil and water)
Old Jan 2, 2007 | 09:02 PM
Ike's Avatar
Ike
Blue By You
Like what? x.x
Dressed is usually the engine including accessories (alternator, AC?, water pump, etc.) and all related belts and fluids.
Old Jan 2, 2007 | 09:04 PM
AdRoCK3217's Avatar
Rotary Superstar
Ah, sorry. I thought we were talking short block. I could go weigh all the accessories <.<
Old Jan 2, 2007 | 09:07 PM
Ike's Avatar
Ike
Blue By You
Get to work!
Old Jan 2, 2007 | 09:26 PM
corvus13's Avatar
pallida Mors
From the pages of the Holy RX8 hardbound book, I quote as follows:
The rotors weigh 8.6 lbs each.
The RENESIS is 30 percent smaller than the twin turbo 13B-REW
I will continue to scour the book for more weights, and will post if I find anything else of interest.
Later
Corvus13
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
