max speed for running stoich with new flash?
Old Jan 1, 2007 | 08:17 PM
turbodiesel_1's Avatar
Does anyone know at what speed the afr comes out of closed loop with the recall flash?
Old Jan 1, 2007 | 09:43 PM
Brettus's Avatar
Boosted Kiwi
its not speed dependent but rev/% throttle (could be load based but not sure )
Doubt they have changed this with the new flash .
Normally
anything above 4000 rpm or 30% throttle will be in open loop but this does vary a little with each gear.
Old Jan 2, 2007 | 03:49 PM
j9fd3s's Avatar
i was under the impression that it went out of closed loop @3750 when the secondaries came online. although i dont really see why, its an NA, and the ecu is fast! the FC's and FD's did the same thing, but they have slow computers, and the fd boosts quickly
Old Jan 2, 2007 | 04:02 PM
zoom44's Avatar
it will also now come out of closed loop on extended cruises on the highway. it switches to an open loop cat prtection enrichment scheme. trigger by cat temp i believe.
Old Jan 2, 2007 | 05:06 PM
StealthTL's Avatar
Metatron
Cool How would you tell?
How would you know when it's in/out?
Would you need an EGT/AFR meter, or is there another way to tell?
S
Old Jan 2, 2007 | 05:08 PM
zoom44's Avatar
scanalyser
Old Jan 2, 2007 | 07:20 PM
yes,
it is cat temp related... it seems most of the time it is 76mph. depending on outside temp...
the drop is not that much.. when it goes into cat saving mode the afr drops to about 14.4 to 14.5.
Old Jan 3, 2007 | 09:54 AM
j9fd3s's Avatar
Originally Posted by swoope
yes,
2%....
Old Jan 3, 2007 | 01:46 PM
MazdaManiac's Avatar
The CAT preservation scheme can drop the AFR all the way down to 11:1 on some people's cars, though typical is 13.2:1.
Happens when the RPMs stay over 4050 or so for 20 seconds at cruise.
Old Jan 3, 2007 | 09:36 PM
Originally Posted by j9fd3s
2%....
yep,
on a light cruise like at 76 mph that is all it takes to drop the cat temps...
Old Jan 5, 2007 | 04:42 PM
j9fd3s's Avatar
yep,
thats good, means i can go faster, and still get decent milage!
Old Jan 10, 2007 | 09:35 PM
PhotoMunkey's Avatar
Yup, this is undoubtably what my car does... Is there a fix for this yet? Changing out the cat or spoofing the temp output from the O2 sensor? Something? I can do 19 mpg at 75-80 mph, and 19 mpg at 90+ on the same stretch of road. In the latter case, as least I'm getting home faster...
Eric
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
cushing75
Nov 12, 2018 12:46 PM
GracefulShanks
Aug 18, 2015 11:40 AM
