Need help wiring LED scanner
Old Dec 31, 2006 | 02:07 AM
VmanX's Avatar
I'm a noob when it comes to anything electrical. I just bought this LED scanner, like how it is in Knight Rider, but I need help wiring it so that it comes on when the car is off as if it was an added security feature. The flashing red indicator in the instrument cluster doesn't serve well for me as a "back off! my car has an alarm," deterrent. The scanner has 3 wires, 1 positive and negative, and 1 for ground, although I don't know where to wire it to. Any input would greatly be appreciated. Thanks!
Old Jan 2, 2007 | 02:48 PM
VmanX's Avatar
Old Jan 2, 2007 | 03:49 PM
LivinLrge's Avatar
Where do you plan on putting it? that way I can tell you at least how I would/where install and run the wires to and from.
Old Jan 3, 2007 | 11:39 AM
VmanX's Avatar
by the steering wheel if possible. Thanks
Old Jan 3, 2007 | 10:13 PM
VmanX's Avatar
what's a good wire to tap into that is activated only when the car is off? anyone?
Old Jan 4, 2007 | 12:02 AM
Xantium's Avatar
Unregistered User
this sounds too cheesy
Old Jan 4, 2007 | 12:31 AM
Xantium's Avatar
Unregistered User
" OoOo.. this is cheesy!
if you have nothing relevant to say, then don't say nothing at all ******"
LOL this is the pm i got from this guy. I better be careful before i insult night rider leds again!
Old Jan 4, 2007 | 09:35 AM
VmanX's Avatar
Scanner is 12V. It's actually a positive, a negative (ground), and one wire which they also label ground but it's for power only when the car is off. It's just about a 4-inch long strip of LEDs with 3 wires coming out of it. I'll try to post a pic later tonight. Thanks
Old Jan 4, 2007 | 09:47 AM
Coop '04's Avatar
DELIVERED 07-17-2004
Sounds like it needs a switched ground on the third wire that is labeled ground. Lots of alarm devices are wired this way. Aftermarket door lock actuators for one can be wired this way.
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
