Car WON'T Start!
Old Dec 30, 2006 | 10:51 AM
RX8_20's Avatar
Car WON'T Start!
it's cold here, i started my car and as i was backing up my car turned off and won't start again. I checked my oil and it is on the LOW line, and i DO have gas. what's wrong with my car? it's a 2004 rx8.
Old Dec 30, 2006 | 10:56 AM
Mazda-Rati's Avatar
the WANKEL made me do it
You may have flooded it. Try the deflooding procedure in the manual.
or this..... https://www.rx8club.com/showpost.php...8&postcount=11
Old Dec 30, 2006 | 11:01 AM
Find a buddy to push start it for you. Its much better and faster to start it like this.
Stay on a Level Street
Turn the key to on (Dont even bother to start it, just leave it at on)
Put your car in N
Find the STrongest Buddy and Push the car from behind so the car move forward (or maybe 2 buddies) till it reach maybe 5 mph (not that hard)
Dump the gear to 1, Hold your Clutch and give it a little gas like when you first try to learn how to drive a stick. and let the clutch go slowly
If its done right(and fast enough) your car will start, why push start cuz is better than Mazda's since it wouldnt hurt your Catalyst Converter much.
Old Dec 30, 2006 | 11:49 AM
RX8_20's Avatar
Put your car in N
its automatic...
Old Dec 30, 2006 | 12:32 PM
mikeschaefer's Avatar
I wanna rock! Rock!
I've done it on autos (other cars)... It's not the classiest way but it gets the job done I suppose. So yeah... try reading the manual. It explains the easiest deflooding procedure. When you hold the throttle all the way down the computer will cut fuel (built-in deflooding code), so when you turn the key to start you'll (hopefully) burn out all the fuel that's in there. It's worked for me and it's much easier than any other procedure (taking out the spark plugs). It will take more than 10 seconds usually to start firing though, so don't get discouraged.
Old Dec 30, 2006 | 12:34 PM
RX8_20's Avatar
got it towed and sent to mazda...
Old Dec 30, 2006 | 12:39 PM
shaunv74's Avatar
Power!!
It's probably flooded. Make sure they check your plugs. They may need to be replaced...and they're not cheap. They should be covered under warranty. Also make sure they check to see if you have the latest pcm flash and updated battery and starter motor. There is a TSB for this search around this forum and you'll find the TSB link.
Not to worry. Just make sure you don't shut the car down until it is completely warmed up in the future.
Old Dec 30, 2006 | 02:24 PM
Mazda-Rati's Avatar
He didn't. The car just cut out while backing up
Old Dec 30, 2006 | 04:35 PM
shaunv74's Avatar
Power!!
Didn't mean to sound accusatory. Strange that it cut out when it's an auto though. I'd be curious as to why that happened. Maybe the dealer can explain. Let us know what they say.
Old Dec 30, 2006 | 11:35 PM
RX8_20's Avatar
i've never had any maintenence done to this car, and they just said i needed new spark plugs, thats it... and i just realized the put a dent in the drivers door and chipped some paint, they said they cant do anything about the dent or paint though
Old Dec 31, 2006 | 12:21 AM
dude,
stop posting this stupid ****....
https://www.rx8club.com/showthread.p...78#post1623078
your ?s have been answered over and over again...
try this hope it helps. and you can always read the owners manual.. hint it is in the glove box...
http://www.albinoblacksheep.com/flash/posting.php
Old Dec 31, 2006 | 10:12 AM
RX8_20's Avatar
xxxxxxxxxxxxxx, just because i dont spend every minute of my day on these xxxxxx forums doesnt mean i cant ask a xxxxxxxx question xxxxxxxx.
Have a nice day.
Last edited by StealthTL; Dec 31, 2006 at 10:27 AM. Reason: Edited to remove personal attacks....
Old Dec 31, 2006 | 10:23 AM
I feel your frustration ...
https://www.rx8club.com/showthread.p...wpost&t=106312
but p1ssy posts like that make you look
EDIT: Looks like Auto stalling is a common issue:
https://www.rx8club.com/series-i-trouble-shooting-95/repeated-stalling-62948/
Old Dec 31, 2006 | 11:04 AM
I wanna rock! Rock!
that's why you should have listened to us and not taken it to the dealer, but live and learn!
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Kangarhew
Jul 18, 2015 08:27 PM
