Car wont start. Weird problem.
Old Dec 28, 2006 | 09:23 PM
Mortal Moxie's Avatar
Taylor not Tyler
Today I reset my computer after swapping out my cold air intake back to the stock air box.
Took it out for a ride, it felt fine. The ride was about 10 minutes.
Came back home. Parked it in the garage.
Went inside for a few hours, had to go out to the market so I went to get in the 8 again.
Won't start.
But before I get in, the remote unlocks the door. The inside lights turn on.
When key is in the "On" position, all the lights are there, then as soon as I turn it to start I hear nothing. All inside lights die, all dash lights die. No clicking from the engine compartment, nothing to indicate that the car is trying to start or turn over. Just a scary silence.
In the dash theres a small red light in the shape of a car that slowly fades out in about 3 seconds.
Wtf is happening?
Old Dec 28, 2006 | 09:37 PM
dead battery?
Old Dec 28, 2006 | 09:54 PM
Taylor not Tyler
Wouldn't I heard the rapid ticking?
Would I have noticed lights dimming, or anything else seeming "not right" before this?
Just seems to have come out of nowhere.
*shrug*
I guess I'll try to jump it in the morning.
Old Dec 28, 2006 | 09:57 PM
dillsrotary's Avatar
jersey fresh
back track the process of installing the stock airbox, seems weird it would occur after reinstalling it.
Old Dec 28, 2006 | 10:17 PM
dynamho's Avatar
I agree w/ dillsrotary.
Old Dec 29, 2006 | 03:59 AM
Originally Posted by abbid
Im willing to bet loose battery terminal..
yep.
Old Dec 29, 2006 | 04:48 AM
Imidazole's Avatar
Battery terminal or you left a light on or something.
Old Dec 29, 2006 | 06:17 AM
Mazda-Rati's Avatar
the WANKEL made me do it
I think its your theft system. Maybe the CHIP in your key went bad.
Old Dec 29, 2006 | 09:34 AM
Taylor not Tyler
I'm willing to bet loose battery terminal..
I hope so. I did disconnect the battery at one point during the process. I'll have to go down and make sure they're connected tight.
Could be gunked up with battery acid also.
ps: On a lot of cars, I've see the white / blueish battery acid fuzz type stuff. The 8 was the first car I've seen have purple goo around the terminals. Weird.
Guys, thanks a lot. I appreciate it.
Old Dec 29, 2006 | 09:36 AM
Taylor not Tyler
So then technically I can use the valet key right?
Old Dec 29, 2006 | 10:33 AM
Mazda-Rati's Avatar
yep. I had a key made when I bought my 8 and the dealers machine was down so they couldn't connect to mazda to program my key. They didn't tell me this until after when I had already tried to use the key and the the car would not turn over. I would get all of the lights and radio and everything, but when I turned it over, NOTHING, no clicks. just the flashing red theft light.
Old Dec 29, 2006 | 11:38 AM
Taylor not Tyler
You were right. One of the terminals was loose enough to freely rotate.
I must have inadvertently loosened it when disconnecting it last night. So I disconnected both terminals, cleaned them, then re tightened everything. Car started. Hoorah.
Took it out for a little morning run. The car runs much stronger now that I have the aftermarket intake removed. But that could also be from resetting the computer.
She's fun to drive again.
Thanks for the other suggestions guys.
Wantingtoknow
Dec 15, 2016 02:25 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
Belalnabi
Jul 17, 2015 07:48 PM
kaboshe
Jul 17, 2015 03:14 PM
