I just recieved this as a Christmas gift and seem to have trouble with the directions........ Has anyone installed it and took the time to takes pics that would direct me on the route to installing it? Anything would help.
Thanks in advance
Sam
olddragger
12-24-2006, 08:19 AM
Its not Christmas yet!
OD
mysql101
12-24-2006, 08:22 AM
scott's directions are pretty clear. You just cut the coolant hose at the 90 degree bend, put the barb part in, then hook up the ground wire. The other end goes into the fuse box (far right side of the car in a black plastic box) and replaces the OEM fan fuses.
StealthTL
12-24-2006, 08:36 AM
".......and replaces the OEM fan RELAYS."
You would still need the stock fuses....
S
mysql101
12-24-2006, 08:39 AM
yup, wrong word. It wouldn't matter - the relay wouldn't fit into the fuse slot anyway :P
OD
We gave out secret santa gifts a little bit early this year haha.
The one thing im not sure on is the location of the coolant hose. Is any coolant going to leak out when I cut the hose?
Sam
expo1
12-24-2006, 03:30 PM
Sam Yes some will leak out, do it on a cold motor and it will not be that much. http://www.rx8club.com/showthread.php?t=97975 Post#17 has photos
mysql101
12-24-2006, 03:59 PM
My car was cold, and I didn't notice any coolant come out. Just have a washcloth handy when you do the initial cuts.
Here's the finished product:
Thanks everyone. Gonna install it, with confidence, tomorrow.
Sam
N rider89
12-25-2006, 01:46 AM
yeah its not too hard but watch out for the coolant. it sprayed be pretty good
swoope
12-25-2006, 02:03 AM
yea,
same here, cold car=no pressure= no coolant. it does not get much more simple than this mod...
enjoy..
beers :beer:
Installed everything! Took about 15 minutes. Really straightforward. Thanks again for the quick help guys. So, how do we know it's doing what it should be? I don't have any type of scanner to check temps and whatnot
Sam
dannobre
12-25-2006, 05:24 PM
You will notice the fans running a lot more than before.......other than that...not much.
N rider89
12-26-2006, 03:53 AM
yeah i can hear the fans a lot more
