car won't start! help!
Old Dec 23, 2006 | 11:09 PM
KhmeRX-8's Avatar
This 1.3 will Smoke you!!
Unhappy car won't start! help!
my car was working yesterday, now i tried to start it and it won't start. it cranks but just doesn't start, does anyone know what the problem is. oh yeah i have an automatic starter, so do you think that will void my warranty cuz i hear that 6speed are not suppose to have an automatic starter. i'm new to this so any help on this will be appreciated, Thanks
Old Dec 23, 2006 | 11:25 PM
Does it sound funny when it cranks...ie no lub lub lub noise......if so probably flooded.
Could be a ton of stuff...including wiring problems with the remote starter wiring.......
Old Dec 24, 2006 | 02:25 AM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
Sounds wierd but you may want to recharge your battery - even if it turns over and the lights come on it seems to need a little extra juice - do the jumper cable thing on your battery, wait about 15 minutes, then retry...If it still doesn't start, next probable is flooding - did you turn it on cold, roll a little bit then turn it off then try to start later? If so - flooding -
Are you running hi test gas?
Old Dec 30, 2006 | 03:32 PM
mkaresh's Avatar
The automatic starter would only affect your warranty if it can be proven to have caused the problem. It cannot void your whole warranty, just coverage on a related issue.
Since I assume you've had the automatic starter for a while, and the car's been starting, battery and flooding are the most likely suspects.
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Kangarhew
Jul 18, 2015 08:27 PM
