Loud Pop
Old Dec 19, 2006 | 02:00 AM
precisi0n84's Avatar
Loud Pop
Hey guys, I'm new to most of this stuff on here, so pardon my ignorance. Here's my issue...
Every now and then I'll hear a loud pop coming from under my car. At that point, driving over 5.5K RPM, the exhaust will be ALOT louder than normal (in any gear). As well as that happening, the car seems to idle rough after that pop. It almost sounds like the pop is coming from my cat., but I could be wrong (like I said, new to this stuff.)
Any information or suggestions would be greatly appreciated. Thanks.
Oh. You'll probably wanna know this information:
2004 AT RX8
AEM Cold Air Intake
Greddy SP2 Exhaust
Everything else stock....
Old Dec 19, 2006 | 02:34 AM
tiltmode43's Avatar
OMGITM!
Hm, you wouldn't happen to be talking about a backfire would you?
Old Dec 19, 2006 | 02:39 AM
Would backfire cause the exhaust to roar at RPM's about 5.5K and cause rough idling?
Old Dec 19, 2006 | 08:49 AM
Go48's Avatar
"Would backfire cause the exhaust to roar at RPM's about 5.5K and cause rough idling?"
A "backfire", as the term is commonly mis-used, is actually an explosion of unburned fuel/air in the exhaust system, sometimes in the catalytic converter. So, if your cat was damaged by a backfire, it could cause idle problems and a change in the exhaust note.
Take it in to a dealer and have it checked out. Also, if you have not had the 4206F recall done, do it now. Be forewarned however, with aftermarket intake and exhaust, some dealers point to that as the cause of any problem and may refuse to do any troubleshooting. Don't be surprised if you get that response at the dealer. Best to at least replace the OEM intake before taking it in.
Old Dec 20, 2010 | 10:36 AM
Gixxerkid13's Avatar
Hey I have the same mods and the other day I heard a light pop and since then everything is a lot louder I do believe its is the cat
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
Jb4ker96
Sep 27, 2015 10:06 PM
just1jack
Sep 9, 2015 04:45 PM
