Cusco Zero 2E/Elect Damping controller
Old Dec 12, 2006 | 01:51 PM
Endless Rotaries's Avatar
Hi Guys,
i've been wanting to bring these coilovers into the country for sometime now but never had the chance to post up the ad.
Specs: Monotube Damper, 8Kg Springs front and 5Kg springs rear. Indpendent ride height and spring preload adjustments. Includes uppermounts on F/R
The nice thing is that these can utilize Cusco's Damping controller so you don't have to get out of the car to adjust the damper stiffness, or remove the rear dampers to adjust them.
Cusco developed a new shock absorber for the Zero-2E that further reduces friction resistance of the dampening force to achieve high performance with the vehicle lowered.
- New design: Side port rotary valve
- New: Reduced friction piston
- New oil reducing cavitation
- New material: Special steel for piston valve shim
OUR GB INTRODUCTORY OFFER CAN BE SEEN HERE:
AUTORND GB: CUSCO ZERO2E AND CONTROLLER
Thanks, Rishie
pjwermuth
Sep 28, 2015 11:36 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
