Renesis seem to like the cold
Old Dec 9, 2006 | 09:51 PM
Raptor75's Avatar
Now that winter is back my RX-8 seem to run stronger in the freezing weather then in summer. No test figures to support this but it dose seem to feel stronger. Anyone else experience this.
Old Dec 9, 2006 | 09:53 PM
Nopstnz's Avatar
OHHH YEAH. I drove around tonight and holy crap does she have some kick. That and combined with her loosening up at 14k miles it feels like a whole new ride!
Clavius's Avatar
Its all about Style...
With the Colder air oh yeah it feels stronger. Plus my new CAT helps with the butt dyno numbers haha.
Old Dec 9, 2006 | 10:01 PM
jus7o's Avatar
gotta love old man winter. I only wish my stock tires werent out of tread or id feel alittle more comfy opening her up in the nice texas winter.
Old Dec 9, 2006 | 10:13 PM
RotoRocket's Avatar
Freely Radical
Colder air makes all engines run stronger.
Cold air compresses fuel into denser matter, thus allowing more fuel to be combusted in any given period.
This is the basic principle that causes supercharges and turbochargers to boost horsepower.
Old Dec 9, 2006 | 10:15 PM
Wilson's Avatar
Peeping over the fence
Simple explaination. Cold air is more dense than hot air. Your engine does run better.
Old Dec 9, 2006 | 10:16 PM
Wilson's Avatar
RotoRocket beat me on the post. He is correct too.
Old Dec 9, 2006 | 10:32 PM
RoXanneBlack8's Avatar
stop flooding ur engines
i thought the thread topic was sarcasm when i read it, they dont like being started up when its cold tho...
Old Dec 9, 2006 | 10:44 PM
BunnyGirl's Avatar
Well, mine doesn't feel "better" in this cold, plus the mileage is worse (although improved from when I had those "issues"). I blame it on our current gas blend, which really sucks. Their attempt to help with winter pollution by putting all kinds of crap in our gas, causes our mileage to go down a ton, which causes us to use up a lot more gas, because it sucks, which wipes out the attempts at lowering winter pollution.
Old Dec 10, 2006 | 12:31 AM
jus7o's Avatar
Old Dec 10, 2006 | 11:19 AM
Raptor75's Avatar
I understand all this but have never noticed as much a difference in summer winter performance as with the RX-8.
Old Dec 12, 2006 | 03:38 PM
9291150's Avatar
In the winter, the 8's tires tend to break away in most gears on dry but cold surfaces, adding to that butt dyno feel.
Much truth to cold air, my old turbo especially felt a bigger boost.
Old Dec 12, 2006 | 03:50 PM
Hotsauce's Avatar
RRDI Member
Yeah put a RB intake with the duct, then you really get some cold air into the engine. It's nice to put my hand on the intake and it is cold as ice during long run on a cold day. All that cold air going almost unrestriced into the Renesis, the car really does run well.
Old Dec 12, 2006 | 03:51 PM
mabdeliz's Avatar
It is actually a number of issues that seems to give combustion engines "better" performance" in the winter. I'll try to explain in my simpleton way. Your engine temps probably run slightly cooler in the winter compared to summer. Internal engine heating far outweighs losses to ambient and so, while you may have a 50 degree difference (arbitrary number) between summer and winter ambient temperatures, your engine may only run a few degrees cooler (I am talking about internals) in the same comparison. Considering this and the fact that air entering in the winter is denser (Ideal Gas Law - gas is more dense as temperature decreases) than air entering during the summer, the car computer compensates for the air/fuel mixture and thus you get "more" expansion force during combustion of the fuel entering the engine.
In other words deltaPV=nRdeltaT (in this case, V and R are constants, n is near constant, T takes enginer temperature into account). Ambient heat losses can be taken into account, but would end up being too complicated to account for here. So, in colder ambient, delta T is larger and therefore so is delta. Delta P is the added "push" you feel in the cold temperatrues.
Although your engine may be running slightly cooler in the winter, the gain from air/fuel mixture is larger than the loss of running at lower engine temperatures (I may have confused myself here, I hope you are able to follow). This is a similar concept to the one cold-air intakes follow.
Again, this is a very "simpleton" understanding of the gains from cold ambient temperatures but it is all simple thermodynamic principles. I am sure some of the more experienced forum members can probably explain it better.
Old Dec 12, 2006 | 05:32 PM
1stgen8's Avatar
You must have gotten all A's in school. In other words....our cars run really good in cold weather and a little better with the use of a CAI in any given temp.....Am I right? Also, correct me if I am wrong.....for every 10 degree drop in engine temp you could possibly gain 1hp.
Old Dec 12, 2006 | 07:11 PM
mabdeliz's Avatar
Talking
I certainly did not get all "A's" in school. Actually, I finished with school some time ago, but a background in Chemical Engineering doesn't hurt . 1 hp/10 deg drop may be a good rule of thumb, although there are certainly many other factors that are not being considered when using IGL. The IGL is just an oversimplified explanation for the increased performance in cold weather, however it is not an accurate quantitative method for determining gains. There are certainly many other factors not considered (engine heat losses to ambient, expansion, etc., etc.). The increase in performance should not be limited to only our rotary engines, but engines in general. Again, this is what CAI are trying to achieve, although I would think these are more "sensitive" to ambient conditions.
Old Dec 12, 2006 | 07:16 PM
Renesis_8's Avatar
I think the renesis likes the cold air. Of course the lower intake air temp. a cooler running engine might play a more important role than you might think... we have a hot burning rotary engine afterall, that is why we have the MAZSPORT FAN MOD. they wouldnt sell something if its useless
________
sweetpussyXxxX live
Old Dec 13, 2006 | 02:56 PM
Raptor75's Avatar
This is more alike my line of thinking then the stock answers provided thus far. I think most of us know that cold air helps the power output of all internal combustion engines but the rotary seems to run hotter then it should. My guess would be for emission reasons so when you run the car in freezing temps it feels that some of then detuning from the hotter engine is neutralized by the colder temps similar to the cooling kit mentioned.
Old Dec 13, 2006 | 03:06 PM
No one likes to work when hot. Engines are no exception.
Old Dec 13, 2006 | 04:19 PM
TomAssBender's Avatar
Skeet skeet skeet
Originally Posted by nycgps
No one likes to work when hot. Engines are no expection.
are you expecting an exception?
Old Dec 13, 2006 | 11:25 PM
I HATE YOU !!!!!!!!!!!!!!!!!
Old Dec 13, 2006 | 11:40 PM
csuttman's Avatar
From: Jupiter, Florida (sure beats Wisconsin winters!)
The difference for me between a 70 degree non-humid day and an 85 degree humid day is like night and day.
I hate the car on hot days because it doesn't have enough power to hardly get going without 4k+ rpms when letting the clutch out.
On the 70 degree days, like we're finally having a lot of... the car is a blast and has plenty of power.
I brought this up on another thread and had a "MazSport Cooling Mod" suggested to me, which I'm definitely going to look into it for hot days.
Old Dec 13, 2006 | 11:43 PM
Xantium's Avatar
Unregistered User
I weep for your clutch
Old Dec 13, 2006 | 11:45 PM
csuttman's Avatar
How much does humidity factor into the equation?
I live in S. Florida and it's really humid here probably 80% of the year. It hasn't been good for my 8!
Old Dec 13, 2006 | 11:47 PM
csuttman's Avatar
Unhappy
Actually... I just posted on another thread a question about upgrading my clutch myself. It is taking some abuse!
