Engine running even after key is pulled out
Old Dec 8, 2006 | 12:09 PM
XMatrix's Avatar
Hi bros and sizs, any of you experience your 8's engine running even after key is pulled out? Mine did but I didnt open ip the hood to check, just went back and plug the key in, twist to on and twist to off and pull out the key. Then the engine stop running. What's happening?
Old Dec 8, 2006 | 12:13 PM
sqflyer's Avatar
Heavy Machinery Operator
I think most likely you mistaken the fan noise as engine running. Either that or someone installed a turbo timer on your 8 without you knowing.
Old Dec 8, 2006 | 12:34 PM
mandotcom's Avatar
ya maybe your cooling fan. are u the one who just got your car?
Old Dec 8, 2006 | 03:07 PM
rayshaw23's Avatar
definitely the cooling fan... mine does the same after i decide to play in the higher rpm region... heeheehee... it just goes off after sometime
Old Dec 8, 2006 | 06:27 PM
lowrider's Avatar
A wanker with the Wenkel
Engine could also be knocking from using the wrong fuel?
Old Dec 9, 2006 | 07:42 AM
coupe07's Avatar
SC 300HP!!
key has been pulled out.... engine shldn run oredi, so cannot be knocking.
Old Dec 10, 2006 | 07:58 PM
madmax_rx8's Avatar
maybe he got a turbo timer hehe
but i think should be the fan cause if the engine is real hot... most of the time.... the cooling fan will still run for awhile..
Old Dec 15, 2006 | 02:31 PM
PitchBlaC's Avatar
Read the user manual. It is the fan. It will stop approximately after 10 mins.
Old Dec 15, 2006 | 08:30 PM
Roulette's Avatar
my car's cooling fan hasn't come on for a while already (used to come on each and every single time after shutdown)
anyone had this prob? me thinks it's busted
Old Dec 15, 2006 | 09:48 PM
1stgen8's Avatar
If it is cool or cold where you are it probably won't. Not this week but it was really cold the last two weeks where I live. I do not recall mine coming on at all. When I pull my garage I always notice it cause I can feel hot air as I get out of the car.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
delicious_dallan
Jan 17, 2020 09:17 AM
Bamaham
Jul 23, 2015 08:08 AM
