ContiSportContact 3 - 8lbs lighter than stock!
Old Dec 7, 2006 | 09:23 PM
brillo's Avatar
Go Texas Longhorns!
http://www.tirerack.com/tires/Spec.j...e1=yes&place=4
must be a brand new tire, since Continentals own website doesn't have the specs yet, if these tirerack specs are correct, that is a pretty amazing weight savings over the stock tires.
I just happen to be perusing the tirerack when I stumbled across these.
I can't make any comments as to the performance, but I liked my Continentals on the Mazda6 I had.
Old Dec 8, 2006 | 12:21 AM
LionZoo's Avatar
road warrior
Holy crap, and I thought the 23 pounds that 245/40-18 Advan Sports weigh were light. The SportContact 3s even in the 245 fitment is only 21 pounds. A tire's weight is not it's most important characteristic, but if reviews of this tire are good I might need to ditch my preference for Yokohamas.
Old Dec 8, 2006 | 12:39 AM
CAM427R's Avatar
That is a pretty large difference in weight. Pretty amazing, I'd like to see what those can do.
Old Dec 8, 2006 | 12:50 AM
Maybe it's a misprint.
Anyhow I wonder if the sidewalls hold up.
some people are complaing about other high performance tires
Old Dec 8, 2006 | 01:10 AM
ZoomZoomH's Avatar
Mulligan User
that's significant unsprung weight reduction, should be noticeable handling improvement
Old Dec 8, 2006 | 03:45 AM
dude.
you gave me wood.. but the 245 40 18 weighs 28 lbs...
i got to go with missprint vana..
please, please, please prove me wrong.. bitch..
Old Dec 8, 2006 | 08:26 AM
brillo's Avatar
Go Texas Longhorns!
My current Pirelli's are 21lbs in a 225/45/18, so I think it is possible, but I'm going to contact Continental today and ask.
With these tires, you really almost don't need light weight wheels, unless you just like the look I guess. I happen to like the stock wheel design, hence my search for the lightest good tires possible.
Old Dec 8, 2006 | 09:49 AM
dgrx8's Avatar
FN GR8
holy crap!
subscribes...
Old Dec 8, 2006 | 10:00 AM
Umbra's Avatar
I hope the improved the tire. The conti's I had were total pieces of crap. Wore really fast and traction was never that great.
Those stock tires on the 8 though are really heavy, just about anything is lighter.
Old Dec 8, 2006 | 10:27 AM
KimiFelipe's Avatar
This is going to be a great tire from what I've read. The contisportcontact 2 is also excellent, while the original contisport contact did indeed suck.
You have to expect a high rate of wear for a top summer tire, Umbra. At best getting a better wearing summer is going to give you 5 k mi or so, but the performance difference will be significant, afaik.
Personally, my favorite tires are the B'stone RE 050, the CSC 2, the Avon Tech M500 (for a cheap alternative), the TOYO T1-R, and the Dunlop 8090 (although for the price this one is just not worth it at all). I want to like the Pilot sport and SO3 pp, but these are too loud.
I can't wait until my 040's wear out - this is loud tire too. OTOH, it's hard to fault otherwise, the grip is excellent, although not as good as the 050.
Old Dec 8, 2006 | 12:37 PM
LionZoo's Avatar
road warrior
Originally Posted by swoope
dude.
That's the runflat version. The normal "Mercedes" fitment is 21 pounds.
Old Dec 8, 2006 | 11:14 PM
The car comes with run flat!
Old Dec 9, 2006 | 01:55 AM
yep,
i chatted with brillo about that today.. i hope this i right... as i am in the market for new tires..
Old Dec 9, 2006 | 08:27 PM
yep,
have looked again, but wtf is mercedes and what wtf does it have to do with tire size...
214 bucks .. thinks
Old Dec 10, 2006 | 12:22 PM
LionZoo's Avatar
road warrior
Mercedes means it's an OEM fitment for some Mercedes model or other. It might be a normal tire that they wanted to identify as a Mercedes OEM fitment, or it could have differences in construction and/or compound that Mercedes requested.
Old Dec 10, 2006 | 11:56 PM
making your choice on weight alone is a big mistake
Old Dec 11, 2006 | 11:28 AM
LionZoo's Avatar
road warrior
Very much so. But if two tires are comparable, then the lighter tire wins. Weight is definitely not the deciding factor.
Old Dec 11, 2006 | 02:00 PM
brillo's Avatar
Go Texas Longhorns!
I'm getting some wierd info on this tire per continentals email from a customer service rep. She said the 225/45/18 was 22.xxlb and the 245/40/18 was 11.xxlbs, obiously wrong.
I called Continental but wasn't able to get any better info. We will have to wait for the tires to hit our shores to know for sure. I'll check back in about a month.
Old Dec 11, 2006 | 04:11 PM
Spin9k's Avatar
Momentum Keeps Me Going
Found these new Continentials here but no specs as you say http://www.conti-online.com/generato...master_en.html
Really cool animated tire movies here http://www.conti-online.com/coremedi...main01_en.html .... use the streaming flash version .... cool for a tire site
Could be something to them if they are so light!!
Old Dec 11, 2006 | 06:58 PM
LionZoo's Avatar
road warrior
I trust tirerack's numbers as they weigh it themselves, rather than use the manufacturer's numbers.
Old Dec 12, 2006 | 07:52 AM
Umbra's Avatar
I realize the wear issue, but when you can chirp the tires going into 5th gear they suck.
Old Dec 12, 2006 | 07:06 PM
KimiFelipe's Avatar
What (not completely worn out) tire have you done this with in an RX-8? I don't believe you, unless you were running a summer tire when its really cold or on ice.
The RX-8 doesn't have that kind of power.
Even completely worn, almost any tire will have good dry traction when its hot out, because of the very high contact patch.
Old Dec 12, 2006 | 07:14 PM
no way,
i doubt a fi motor could do that... or were you driving in snow?
Old Dec 12, 2006 | 08:29 PM
anybody that races can tell you that your comment above is BS
Old Dec 12, 2006 | 11:50 PM
Slippery slide on my bald tires with high contact patch. It's hot out!
