oil in intake?
Old Dec 7, 2006 | 01:00 AM
LiL BenNy's Avatar
Bubblicious? DEF.
oil in intake?
so during the install of my AP pulleys i had to remove my AEM cai. (by preferrance) while i was doing so i notices a little oil in my intake tube and along the rubber connecters.. is this normal? what should i do? should i be concerned?
Old Dec 7, 2006 | 05:51 AM
Theres a Search button at the top of the page.
Old Dec 7, 2006 | 10:29 AM
Silver_Surfer's Avatar
I4NI
Only if you.........
Old Dec 7, 2006 | 05:28 PM
LiL BenNy's Avatar
Bubblicious? DEF.
and what do you suggest i search? oil in intake? cuz a billion threads come up that are irrelevent to my oil in the intake. if theres another name for this please let me know, obviously i have no clue about this situation so i dont quiet know what to search for
Old Dec 7, 2006 | 05:34 PM
turbosa22c's Avatar
do you have that hose thats connect from the filler neck to the intake tube? oil is being pulled from the pvc system. its kinda normal on all cars. that is how we get carbon build up on the throttle body. you could use a sealed catch can, to accumulate the oil.
BLKrxEIGHT's Avatar
That is the most retarded thing to tell someone to search for. Either offer helpful advice or dont say anything. People like you are the reason I just read and never post.
Old Dec 7, 2006 | 08:14 PM
snipaz2420's Avatar
the bukkake master!
i kno that its a different intake all together, but one time with my K&N i had an oil change and the guy spilt oil all over the engine bay and when i went to clean the intake filter there was a little oil behind the filter and some in the pipe itself. i dont kno if this helps but this is from my own experience.
Old Dec 7, 2006 | 11:52 PM
ddub's Avatar
always preoccupied.
Actually it's not the most retarded thing to search for. This was a somewhat big issue for a lot of early rx8's who had oil pooling (noticeable amounts) in the intake. Tons of threads about it.
Old Dec 8, 2006 | 12:28 AM
Seems to come from filling the oil tto fast or overfilling way too much.
Go to DIY to find a a bypass thread to vent the system.
Old Dec 8, 2006 | 03:38 AM
it is by over filling or a funnel that does not go below the top tube in the oil fill tube..
Old Dec 8, 2006 | 04:04 AM
The Ace's Avatar
Greek Power
Solution is simple: oil catch can. The problem is: where to mount it ?
I have tried to install it in at least 5 different spots, but it simply doesn't fit anywhere Main problem is the height. Next to the battery, next to the water bottle for the wipers, next to the master vac, next to the intake box, nothing......
Any ideas ?
Old Dec 8, 2006 | 04:06 AM
shorter catch can..
Any ideas ?
Old Dec 8, 2006 | 08:07 PM
ucleadguitar's Avatar
6 spd Newbie
Or just use a breather filter you can pick up from AutoZone and cap the intake port.
Old Dec 8, 2006 | 08:58 PM
mikeschaefer's Avatar
I wanna rock! Rock!
ghetto!
Old Dec 18, 2006 | 01:11 AM
sosonic's Avatar
Interestingly, I have not seen too many RX-8s in the ghetto.
Old Dec 18, 2006 | 02:57 AM
6 spd Newbie
Originally Posted by mikeschaefer
ghetto!
What's ghetto about a Breather instead of the return line to the intake?
Old Dec 18, 2006 | 06:59 AM
I wanna rock! Rock!
I've used them before and they don't catch as much as you'd like. That's if there's even enough pressure in the crankcase (and most think there isn't) to push oily vapor out. If that's the case then it's still useless.
Old Dec 18, 2006 | 08:06 AM
mysql101's Avatar
I did both...
oil catch can, with a breather on the end of it.
My catch can is about half way full right now, need to dump it soon.
Old Dec 18, 2006 | 08:52 AM
dgrx8's Avatar
FN GR8
Originally Posted by mysql101
I did both...
do u happen to have a picture of your setup??
Old Dec 18, 2006 | 08:55 AM
mysql101's Avatar
I'll snap some new photos tonight - if I don't forget.
Old Dec 19, 2006 | 09:32 PM
CURED RX8's Avatar
I like the color
mysql101...Love the Lord of the Rings reference.
See this from another thred on Oil Catch Cans:
http://www.finishlineperformance.co...050-06-1664.pdf
If you prefer, you can get the new '06 setup done at the dealership. No need for the Oil Catch Can.
Edit: I don't think the link is working, I'll try and find the thread again!
File Type: pdf
Old Dec 20, 2006 | 07:29 AM
I wanna rock! Rock!
So they use lower intake manifold vacuum to pull the oily vapors in, much more close to the combustion chambers. If I had to make an educated guess, you probably wouldn't want this done if your car is boosted.
Old Dec 24, 2006 | 04:12 PM
mysql101's Avatar
As promised..
The breather is dry, so it looks like the catch can is working extremely well.
Old Dec 29, 2006 | 04:01 PM
sosonic's Avatar
I'm thinking about doing this mod. The above pics, by mysql101, are nice.
But I have a problem deciding to go with the catch can and breather, in-line filter, or the 06 Mazda mod where the return line routes to the lower intake manifold.
With the catch can and breather I'm confused about the vacuum pressure issue. It appears that some people are saying that no oil vapors actually make it to the catch can and breather. Is the filter on the breather good enough to protect you and the inside of the engine compartment from oil vapors? Is that really safe?
Even if that is the case, it appears that no oil vapors and weird condensed gunk are getting into the intake. That means only fresh air into the intake? So, it would appear that means better performance?
With the 06 Mazda mod, the oil vapors route to the lower intake manifold. I understand that this would bypass having gunk condensing in the air intake. But you are still mixing "dirty air" with fresh air. So, would this not still be limiting your performance?
Also, is it me or is there a flaw in the 06 Mazda mod? I would think that before you run the oil vapors into the lower intake manifold or even the air intake that you should have a filter to out "dirty air and vapors". In the Mazda mod, it seems that a filter to "clean the air/vapors" would make sense, so that you have cleaner air and higher performance.
So, would it not be better to simply put a filter on the return line, regardless if it goes to the air intake or lower intake manifold? This of course is what the "catch can" concept is partially about, but is a brillo pad a truly effective filter? Would an effective filter not be better than a "catch can"?
In other words would not a good in-line filter (that is a good oil from air separtor) on the return line between the air intake or lower intake manifold be the "end all" to "dirty air", "oil vapors", and condensed gunk.
If so, than what is the best type of in-line filter?
I'm interested in which options people think is better to do.
Old Dec 30, 2006 | 07:30 PM
dgrx8's Avatar
FN GR8
regardles... u'd still have hot nasty oil vapor entering the intake manifold.
i've had just a breather attached for months now & i have not noticed any oil vapor sludge anywhere in my engine bay. the only thing is... i'm starting to wonder if all the vapors are causing building in the oil system. the only problem w/ the crankcase breather as mentioned on all the threads here... is the doubt of insufficient ventilation due to not providing any vacuum...
