Motor Mount TSB
Old Dec 1, 2006 | 10:54 PM
tmak26b's Avatar
Motor Mount TSB
If you havent had your motor mounts, REPLACE it. Mine were actually looking good, but the dealer was nice enough to replace it. After they fixed it, my car idle 100 times better. If your dealer wont replace it, find someone who will. Rotary engine is suppose to idle smooth, not rough.
Old Dec 2, 2006 | 09:45 AM
IT always idles smooth, it shakes because the motor mount has some crack then it moves around.
Old Dec 2, 2006 | 01:42 PM
LionZoo's Avatar
road warrior
Replace it even if your car is out of the VIN range?
Old Dec 2, 2006 | 01:44 PM
mysql101's Avatar
At idle, you should not feel ANY engine movement. The only part of the car that you should feel it is in the shifter.
Even if you're outside the VIN range, if you're feeling vibration in the car, you should have it checked out, or do what MM recommends and have your mounts filled with something like silicone.
Old Dec 2, 2006 | 02:22 PM
Let me the first to welcome you to last year ...
Old Dec 2, 2006 | 04:45 PM
Clavius's Avatar
Its all about Style...
My Service Dept said its normal........................... "all engines shake man your supposed to feel it."
Today I put a plastic bag filled with a few things in my passenger seat and while at a stoplight I could hear the bag rustle as the can of tire washing foam vibrated in the seat. At times I feel it through my A/T shifter and steering wheel. I know these guys and they'll most likely blow me off. Hell its been in the shop on average once a month since I've owned it thankfully for small things but this is annoying me since yeah gonna call up this other dealership a friend mentioned.
Old Dec 2, 2006 | 05:10 PM
SlayerRX8's Avatar
'03 Dodge Viper
Yeah I took my AT in for this issue and the vibration is AWFUL under 1000 rpms...especially when it dips down around 800rpm at idle. They said "we could find any vibration. The other day I left the car running, and popped the hood. I could see the engine physically shaking back and forth, which was making my car a giant vibrator. I got really pissed off at the service techs after seeing this.
Next time I'm going to go in there, popping the hood, showing them exactly how much the engine is shaking and hand them a printed up sheet with the TSB. It's rediculous.
Old Dec 2, 2006 | 05:15 PM
Clavius's Avatar
So far the colder it gets the worse it seems to be getting. In the summer I hardly felt it and just chaulked it up to the engine since I was used to my trucks V6 which did shake obviously but not enough to cause me any concern.
I'm hoping this or any new dealer I bring it to when I mention it will correct the issue for me.
Old Dec 2, 2006 | 05:39 PM
r0tor's Avatar
YES!! everyone run out and demand more parts to be fixed that aren't broken on your car so we can continue our never ending quest to flush this car's reliability ratings and resales value down the *******!!!
woo!! go team!!
Old Dec 2, 2006 | 05:51 PM
Clavius's Avatar
^So your saying my car should vibrate so much it could double as a womans b.o.b. while she is in my passenger seat?
Old Dec 2, 2006 | 06:29 PM
tmak26b's Avatar
woo!! go team!!
What do you not understand? The original part looked good, but the IMPROVED replacement part made idle better. You don't care about having a broken car, but I like mine perfect. If you are in the New England area, let me know. I will tell you where to go and I can send you a receipt of my work. I will also tell the service writer on Monday that it did fix the idle problem.
Old Dec 2, 2006 | 06:30 PM
tmak26b's Avatar
Change the motor mounts, idle will be much better! Dont let those idiots at the dealer dick you around, tell them to lick your I had to burn 2.5 gallons of gas to go to a dealer that would do good work.
Old Dec 20, 2006 | 09:41 PM
SlayerRX8's Avatar
'03 Dodge Viper
Update on my situation - I took my car back in, popped the hood to let them look at the engine vibrating. Plus once it gets warmed up I'd get a rattle against a heat shield in the front. Today they called me up and told me they were sorry they doubted me last time, and that I was exactly right. They're giving me a free tank of gas as a way of saying sorry.
I'll get my car back in a couple days (they have to order the new mounts). I can't wait to have a vibration free/problem free car again!
Old Dec 21, 2006 | 06:28 PM
tmak26b's Avatar
See, you can't trust hte idiots. You have to be annoying sometimes.
Old Dec 23, 2006 | 03:09 PM
Brice-RX8's Avatar
I agree, I just had the motor mounts changed out on my car and now it is smooth as glass at idle. The only thing they didn't do is put the new motor bracket on the with heat shield on the passenger side, hopefully these mounts will last without that.
Old Dec 25, 2006 | 11:21 PM
tmak26b's Avatar
The idle is better, but still not perfect like my RX-7
Old Dec 25, 2006 | 11:25 PM
My 84 first Gen idles way better than the RX-8 as well...but it is running way richer and has a lot less polution control crap....IE none
bosstin87
Oct 5, 2015 06:52 AM
ShellDude
Oct 1, 2015 09:55 PM
Luke.s
Sep 30, 2015 05:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
