winter tire pressure?
Old Nov 29, 2006 | 09:51 PM
dupa12345's Avatar
so i just finished putting my blizzaks on and our little car opump shows them at 2.5 .. my oems were at 2.0 does that seem right?
btw, is my tpms going to freak now? i think i read its just a warning light right?
Old Nov 30, 2006 | 07:57 AM
bsteimel's Avatar
Nice !!!
the meter on my compressor was really off, get a tire pressure gauge from your local auto store and find out the PSI it should be 32-34 PSI. don't go by the gauge on the compressor by any means. The exact pressure is on the back edge of your driver side door.
Old Nov 30, 2006 | 10:40 AM
dupa12345's Avatar
good to know since last time i just went by the compressor .. i guess i have to look for my pressure gauge .. damn
Old Nov 30, 2006 | 10:47 AM
dupa12345's Avatar
though it would be that much off ... assuming the conversion is PSI = 14.696 x atmosphere my 2.5 would be 36.7. So just gotta lower it a little to 2.3 or 2.4.
I guess the question remains whether winter tires need any adjustment in pressure or are they run based on the same recommendation as oems?
Old Nov 30, 2006 | 06:13 PM
tmak26b's Avatar
If they are the same size, just run them the same, maybe slightly more to decrease the contact patch and get a stiffer sidewall to get the same turn in.
Old Nov 30, 2006 | 07:14 PM
Huhwha's Avatar
I've had mine on a week or so. I cranked then up to 35 psi to help offset the saggy sidewalls, but there's a limit somewhere. The bigger problem I think is riding on those independent tread blocks - very squirmy! Spring can't come fast enough for me!
Old Nov 30, 2006 | 07:22 PM
dupa12345's Avatar
theyre 17s .. they ride pretty well .. ill sort that pressure out over time .. so far they look ok
crimson809
Aug 14, 2016 10:03 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
drlubell
Sep 26, 2015 11:58 PM
Snrub
Sep 21, 2015 06:54 PM
