When i get up to high rpms and punch it bad stuff happens!
Old Nov 27, 2006 | 01:27 PM
Ktreece777's Avatar
I have the REVi intake and thats the only mod I have. My problem is that when I am up high in rpms and punch it to redline it feels like I have lost alot of power and then sometimes the check engine light blinks for a little bit then goes off... Anyone experienced this problem?
ONE OTHER THING! : When the car starts I also notice it takes a little longer before it fires up
Old Nov 27, 2006 | 01:36 PM
Phantom Menace's Avatar
II SOCIETY
does that intake require modifying the ECU? Maybe it's leaning out your mix?
Old Nov 27, 2006 | 01:39 PM
Red Devil's Avatar
No it doesn't. Misfire would be my guess also. Check coils and plugs.
Old Nov 27, 2006 | 01:40 PM
maxxdamigz's Avatar
Baro Rex
Go to an advanced auto or some other chain parts store. They will usually pull your stored ECU codes for free in an effort to sell you the junk you "need" to "fix" it. Once you know what the code is, diagnosis is much easier. I used to get codes pulled at AutoZone all the time. A shop might charge an $80 diagnostics fee. The nice code machines are wicked expensive.
Old Nov 27, 2006 | 01:47 PM
mysql101's Avatar
canscan costs about $120. but you'll need a laptop to use it.
scangauge 2 costs about $155, it has a lcd screen but its functionality is more limited than the canscan. It's standalone so that's why I own one.
both will let you read and reset CELs. Very useful rather than waiting around and guessing what might be wrong.
Old Nov 27, 2006 | 01:53 PM
expo1's Avatar
He's as bad as Can
Doing that with a low amount of fuel can also cause the misfire. Try it again with a full tank.
Old Nov 27, 2006 | 01:55 PM
MadDog's Avatar
Consiglieri
Flashing CEL indicates a misfire and will not store a code - at first anyway.
Check plugs first. Then coils.
Old Nov 27, 2006 | 03:00 PM
StealthTL's Avatar
Metatron
Cool Sounds.....
Sounds like my problem, now cured - a few corners at 6k then punch it, it misses.
Mine was a weak fuel pump, but one thing to check would be the little vacuum tap under the throttle body, if you have a REVI it should be capped off, maybe they missed that.
S
Old Nov 27, 2006 | 03:13 PM
h-khunterkiller's Avatar
for hire
i had and have the same problem half an hour after heat soaks the components the fuel pump starts acting up
Old Nov 27, 2006 | 05:34 PM
Paul_in_DC's Avatar
Rotary Public
You can buy OBDII/CAN readers for as low as $50 that will read the codes and reset the CEL. What do canscan or scangauge do that the low-cost readers won't do?
Oh yeah, and misfire CELs are very common at the track for RX-8s.
Old Nov 27, 2006 | 05:42 PM
mysql101's Avatar
Well, first you have to be careful about the low cost readers, as being ODBII doesn't mean much, it must be able to use CAN or it will do nothing.
Both the canscan and the scangauge (with optional upgrade) can log information and allow you do monitor and tweak settings for things like the CZ. You can also read from pretty much any sensor in the car. So it's more than just a CEL reader.
The scangauge II allows you to pick up to 4 of the sensors it reads and display on the screen. So for example, you can monitor ignition timing, mpg, intake temp and coolant temp.
I picked the SGII because it's powered by the obd2 port, and has a built in screen, so there's less wires and no need for a laptop or pda. Mount it on the dash and i'm done.
Old Nov 27, 2006 | 05:44 PM
mysql101's Avatar
here's the canscan:
http://www.obdscan.net/canscan.htm
here's the scangauge II:
http://www.scangauge.com/
Old Nov 28, 2006 | 01:34 PM
Charles R. Hill's Avatar
Owner of BHR
How does either of those compare to the new MSD Dashhawk?
Old Nov 28, 2006 | 01:44 PM
mysql101's Avatar
DashHawk looks like it has a nicer screen and a few more options, but i've never seen it in person and have no idea what the price tag is.
Old Nov 28, 2006 | 02:34 PM
Owner of BHR
MSD says that the Dashhawk gathers not only engine data and code info but also measures 0-60 and 1/4 mile times. The problem I have with these types of performance meters is that they access the wheel sensors for acceleration times, thusly assuming 100% traction through the run. Unless I am wrong and they have accelerometers built-in. Then I am the one doin' the assumin'.
drebbrnator
Dec 27, 2018 07:02 PM
cushing75
Nov 12, 2018 12:46 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
uZu
Dec 30, 2015 12:35 PM
vetteor8
Jul 25, 2015 11:43 AM
