Fuel overflow at the pump
Old Nov 21, 2006 | 08:58 PM
maskedferret's Avatar
Oooh, shiny!
Over the years I have owned a car, maybe once has the gas pump overflowed before automatically capping off... Now, after the 4th time of filling up my (new) car it has happened twice already; what gives? The pump will automatically cap off, but it will overflow and leak down the side of the car -- nothing major, but enough to want to wipe it off the side with paper towels, and it is quite annoying. Anyone else get this often?
Old Nov 21, 2006 | 09:04 PM
mysql101's Avatar
i got that at a specific fuel pump at a local shell gas station, the other pumps work fine...
Old Nov 21, 2006 | 10:05 PM
ken-x8's Avatar
That happens to me at most pumps, if I have the nozzle on automatic at the highest rate. I find that it won't overflow if I've got the nozzle on the slowest notch.
I'm too impatient to fill at the slowest rate. I have a reasonable idea of how much gas it's going to take, so I fill at high rate until I'm within a couple of gallons of that, then drop to the lowest notch.
If this happens regularly, the spilled gas is not going to do the paint and sheet metal any good. I've got an Accord where the sheet metal around the filler is rusted out, pretty much because I wasn't diligent about avoiding and cleaning up fuel spills. If this happens with my 8, I use the gas station's windshield cleaner as well as paper towels to clean it up.
Ken
Old Nov 21, 2006 | 10:28 PM
Yep filling to fast.
Never happened to me on the RX-8 before.
Old Nov 21, 2006 | 11:30 PM
rglbegl's Avatar
Baned
Thank goodness I am not the only one. Happens all the time. I have prepared for it now. I pre-pack a couple paper towels by the filler and DO NOT TOP OFF THE TANK!!!!!
No spillage now that I started using towels. Tiny burps of fuel get soaked up.
And yes SHELL is worse than others.
Old Nov 22, 2006 | 12:10 AM
tiltmode43's Avatar
OMGITM!
I almost always leave it on the fastest notch or hold it all the way untill it cuts off and have never had this problem. And shell is my station of choice (whitewater pearl and shell just go together)
Old Nov 22, 2006 | 04:32 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Another design defect on the 8. It happens way more than any other car I have ever driven.
Old Nov 22, 2006 | 05:59 PM
FlyLow's Avatar
This happens to me all the time no matter how fast I refuel the car. Sometimes I think I wipe off more gas then I put in it.
Old Nov 22, 2006 | 06:11 PM
Nubo's Avatar
Lubricious
If this were a design defect it would be affecting most if not all RX-8. It doesn't. There is a flap in the filler neck that is supposed to shut in case of a rollover accident. In these overfill cases there may be a problem with the flap partially deployed. You should get it checked. Engineers do not design cars to spill fuel.
Old Nov 22, 2006 | 07:42 PM
snipaz2420's Avatar
the bukkake master!
it happened to me once when i tried to squeeze in a few more cents. needless to say i dont do that anymore. once it stops i wont try to put anymore in.
Old Nov 22, 2006 | 08:48 PM
Oooh, shiny!
It COULD be something with the individual pumps I used; so I guess I'll be wary of using those again. (I pretty much stick to QuikTrip.)
Old Nov 23, 2006 | 10:55 AM
You put to much faith in engineers. So much for the engineers that designed those visors.
Old Nov 23, 2006 | 11:06 AM
ken-x8's Avatar
What makes you think everything is designed by engineers? An awful lot of stuff is designed by designers. Sometimes by someone who's just a parts-picker.
The overflow deal with my car varies from pump to pump. I've got it under control by slowing the fill as it approaches full, but I think I'll mention it the next time I bring it in for service.
This is the kind of thing that, if common, can lead to a safety recall. I won't drop the dime (Zoomie is family) but has anyone reported this to NHTSA?
Ken
Old Nov 23, 2006 | 11:11 AM
Xantium's Avatar
Unregistered User
Never happened to me and i always refill at shell on the fastest setting.
Old Nov 23, 2006 | 11:13 AM
TRZ750's Avatar
After 3 years and 26K miles I have never had this happen. Always use the fastest setting and top off after the pump shuts off.
Old Nov 23, 2006 | 11:18 AM
WhiteDealershipRice's Avatar
Has only happened once, and it was when I tried to squeeze those last 15-20 cents to round it up to the next dollar... needless to say I now only round to the nearest 5-10 cents. has not happened since, andI'm very careful to clean any spilled drops
Old Nov 23, 2006 | 12:06 PM
Vash137's Avatar
Happens to me at most stations...Exxon seems to do it less often than most. I always just run the car down the the fuel light..when I get around 11 or 12 gallons slow the pump down until its full. Might still get a little burble so I keep a rag with me at all times. Is this possibly an issue with '06 models?
Old Nov 23, 2006 | 01:33 PM
climacus's Avatar
If you search this forum you'll see that it has happened to many people before. Make sure the nozzle is snug and slow down the fuel flow when you're close to the top. The filler neck makes a different noise when the tank is almost full. Plus you can look at the trip odometer and do a quick calculation in your head on how much fuel you need.
The one time I overfilled, I spilled over a liter of gas. I wasn't paying attention when it started, so by the time I looked down, it was like the Niagara Falls. It was all over my quarter panel, bumper and rear wheel. Took all the brake dust off my rim. Good thing my brake wasn't hot.
Old Nov 23, 2006 | 03:01 PM
Endor's Avatar
Vroom
Never happened here, and I habitally try to top the tank off or round it to the nearest dollar. I've overfilled in a CR-V twice though.
Old Nov 23, 2006 | 03:37 PM
Phantom Menace's Avatar
II SOCIETY
Happened to me the very first time I filled my 8 up. You know, the free tank the dealership gives...I hate using paper towels cause I know it'll scratch but I had to the first time. I, too, use the soapy water from the squeegie to "rinse" off any left over gas. Now, I keep a microfiber towel (10 pack for $10 at Kragen) in the trunk. One for the windows, does not scratch tint; one for the exterior; and another for gas.
When washing/detailing, I make sure to put at least two coats of wax inside the fuel crevace--hole where gas cap is--and on the rear fender just incase of gas spills.
RX8strakes.com sells a cool gizmo, by the way, that holds the fuel cap for you while fueling. Some hook it to the gas door hook, and I've even heard of some cut the line. But this gizmo is a neat folding platform that is grippy and will hold the cap and spring shut when the cap is removed. Why Mazda forgot a gap holder is beyond me.
HAPPY THANKSGIVING!
Old Nov 23, 2006 | 04:39 PM
ucleadguitar's Avatar
6 spd Newbie
This happened to me for the first time the other day. About a 1/2 gallon wasted before i noticied....lost that $1.30
Old Nov 23, 2006 | 06:32 PM
captain kenny's Avatar
First time post....I have had my 8 for about 5 months, 2006GT. Have been on the site on and off for a year or so but I am having the same issue and thought I could help. It has taken three trips to the dealer but they have ended up replacing the tank. For the first few months the car filled up fine, then it started to overflow, at first I thought it was the different pumps but it was every pump. The first trip yeilded a call to Mazda and they said to check the vent hose for kinking etc. Trip two they replaced the cannister/filter and a few other parts that could be replaced. Nothing worked so it was determined to be a vent piece (sorry do not know the proper name) but in the 8 this piece is part of the tank. The service manager said that with a lot of other manufacturers this piece can be changed but not with Mazda's so the tank has to go. I know I left out the proper name of the vent part but maybe someone else can figure out what I mean by my description.
Old Nov 25, 2006 | 08:18 PM
Nubo's Avatar
Lubricious
Ken
This is basically what I meant. A detail like an overflowing fuel tank is not going to be overlooked. It's not just a cosmetic thing it's a big safety issue. That means *most* RX-8 probably do not have a problem or it would have (a) been caught by Mazda or (b) it would already have prompted a recall.
That we keep seeing posts like this may indicate that some percentage are having a problem, perhaps due to a parts failure. These should definitely be brought to the attention of Mazda, and not just try to live with it by finessing the pump. Fuel spillage should NOT be happening. And yes, it wouldn't hurt to report to the DOT or NHTSA if you're sure you were pumping properly and the pump wasn't faulty. If they get enough reports it will definitely be looked into.
Old Nov 25, 2006 | 08:38 PM
USNRET P3 Flt Engnr's Avatar
Same thing happens to me. '06 GT. Doesn't matter which brand fuel, or which pump at the usual station. It will "burp" out a few ounces. I thought it was just a quirk with this car. I have backed off the fill rate to the slowest and do the final top off as stated in an earlier post. Haven't had it happen to any other cars ovet the many years I have been pumping gas. My routine now involves folding one of the station's blue towels to go under the filler neck ledge to try to catch the spill.
Old Nov 25, 2006 | 09:12 PM
Gray06's Avatar
GR8FUL
I have only had the car 2 weeks and I filled it for the second time today. The first tome it spilled. I was trying really fill it to the max. Today iI used a slower rate stop after it shutoff.
550 miles the the 8 gets better with everyone.
Bruce
